Cube Copy TI Process
- Version: 10.2
Hi friends,
I am still fairly new to TM1 and am requesting your earnest guidance in solving the below problem of mine.
I have a Cube upon which there is a TI Process defined for copying data within the cube for the whole year based on the Scenario, Version and Division selected by the user (from a source Scenario, Version , Division to a destination Scenario, Version & Division).
Thus, it is copying the data for the whole Year currently.
But right now, business requirement is copy it for a specific month. For example, Business wants to copy the CurrentBudget Scenario data for January month to Forecast scenario and January month - they should be able to do it by selecting a specific month.
Currently in the TI Process, in the PROLOG, it is creating subsets based on Scenario, Version and Year.
How should i approach in solving this problem? Being a beginner to TM1, it is really difficult to come up with an approach to solve it.
I request your help please.
Thanks so much,
srp
Thanks so much,
srp
Best Regards,
srp
srp
Re: Cube Copy TI Process
Add a parameter two parameters to your process, pSourceMonth and pTargetMonth. Then create a subset in both the source and target views and add the new parameter elements to those subsets. This will narrow it down to just the single month.
- Version: 10.2
Thanks so much @tomok for replying!
i. I have created 2 new parameters pSourceMonth and pTargetMonth.
ii. Under Prolog, since it is copying data within the same cube, i have added the below code (Code for Year subset was existing and i have added the Month Subset as mentioned below)
iii. under Data tab, i have added pTargetMonth:
But while executing the TI process for copying data from say CurrentBudget Scenario data, January month,2017 to Forecast scenario, January month,2018 - although it is copying some data but the data are not exactly same.
For example for month Jun:
Output values between Source and Destination Months are not matching
Output:
For JUNE
( source:CurrentBudget Scenario)
Where i am going wrong?
#------------BEGIN Year----------------
#vDimName = 'Year';
#vSubsetExists = SubsetExists ( vDimName, cSubsetName );
#If (vSubsetExists = 1);
# SubsetDestroy(vDimName, cSubsetName );
#EndIf;
#SubsetCreate ( vDimName, cSubsetName);
#SubsetElementInsert ( vDimName, cSubsetName, pFromYear, 0);
#ViewSubsetAssign (cCubeName, cViewName, vDimName, cSubsetName );
#----------END Year------------------
#------------BEGIN MONTH
vDimName = 'Month';
EndIf;
SubsetElementInsert ( vDimName, cSubsetName, pSourceMonth, 0);
#----------END MONTH
#Code to check If both source and target are same
If(pFromScenario @= pToScenario & pFromVersion @= pToVersion & pFromYear @= pToYear);
ProcessQuit;
Endif;
vDimName = 'Version';
IF((ELLEV(vDimName,pToVersion) > 0));
ToVersion=vVersion;
ELSE;
ToVersion=pToVersion;
ENDIF;
#LOADING AND COPYING DATA FROM EXPENSE PLAN TO EXPENSE PLAN CUBE
IF(CellIsUpdateable('ExpensePlan',pToScenario,ToVersion,pToYear,vCurrency,vDivision,vProjects,pTargetMonth, vExpenseAccounts)=1);
CellPutn(vValue,'ExpensePlan',pToScenario,ToVersion, pToYear,vCurrency,vDivision,vProjects,pTargetMonth,vExpenseAccounts);
EndIf;
Output:
For JUNE
105,470,996.94 | ,70,574,387.07 | ,3,192,752.15 | ,0 | ,3,054,637 | ,33,028 | ,105,088 | ,0 |
145410230.4 | ,79256825.71 | ,3571616.785 | ,0 | ,3415239.785 | ,37394.5 | ,118982.5 | ,1.36666E-06 |
Best Regards,
srp
srp
Why do you have all the code referring to the year commented out?
- Version: 10.2
I am so sorry Tom for the mistake. In a hurry to implement it, i missed out uncommenting the Year Code.
Thanks much for pointing it out!
Now the values are being copied correctly for an individual month
- one more question to you please Tom?
Assuming a requirement is to copy data for a particular Source Scenario to Destination Scenario from month to month irrespective of any Year.
Does this mean only Scenario, Month subsets would be created in Prolog and Year subset has to be removed - will this work?
Best Regards,
srp
srp
- macsir
- Version: PAL 2.0.9
You don't need to remove year. As long as you get all level 0 elements from year dimension, it still can remain.
But for easier coding, I would like to remove it and make sure your extracting view is suppressing zeros and skip consolidations.
- Version: 10.2
Thanks macsir for replying! I understood what you have mentioned - could you please let me know more on why we need to suppress zeroes and skip consolidations as you have mentioned.
On top of this, I have a new requirement where business has asked to modify this TI Process to implement the copying of data for individual months as well as YTD Months .
Month dimension has an YTD subset containing elements such as JAN-YTD (Jan), FEB-YTD (Jan, Feb),MAR-YTD (Jan, Feb, Mar) and so on till DEC-YTD(contains Jan to Dec).
They want the elements of this YTD subset to be passed by them as parameters in order to execute the TI process.
So essentially,
Right now Month subset is being created as mentioned below:
I was thinking this should have worked but it is not.
Anywhere i am going wrong? Please let me know your suggestions.
So essentially,
- if user passes MAR-YTD, the ti process should copy data for Jan, Feb, Mar from Source to Target Destination Scenarios and Year.
- if user passes JAN-YTD, the ti process should copy data for Jan-YTD i.e. Jan.
- if user passes only a single month within any of the YTD like say , user passes only June, then the ti process should copy data only for JUN month.
This gets executed and copies the data correctly if i pass individual months like Jan, Feb , etc to it. But if i pass a YTD element from Month dimension like say JUN-YTD, the process executes successfully but no data is being copied for the months Jan to Jun.#------------BEGIN MONTH
vDimName = 'Month';
EndIf;
Best Regards,
srp
srp
The issue is that when you decide to copy a YTD element you are creating a subset with the YTD element instead of the individual months underneath that YTD element. You can't do that because you can't write to a consolidated node, only the leaf elements below it. You need to modify your subset creation process to add only months, not the YTD element.
I would do this by creating the subset with an MDX expression, instead of a hard-coded subset. If you use code like this:
This will result in only months, regardless of whether you pass a single month or YTD element. If you pass Mar-YTD, it will result in Jan, Feb and Mar and if you pass Mar it will result in Mar.
sMDX = '{TM1FILTERBYLEVEL({TM1DRILLDOWNMEMBER({[Month].[' | pMonth | ']},ALL,RECURSIVE)}, 0)}';
- Version: PAL 2.0.9.18
Tom is right. I use code like this:
sMDX = '{TM1FILTERBYLEVEL(DESCENDANTS([Month].[' | pMonth | ']), 0)}';
IBM Champion 2024
IBM Champion 2024
- Version: 10.2
Thank you so much Tom and Wim for your pointers. I am now trying to find out more ways to learn mdx.
Best Regards,
srp
srp
