Description:
What does the customer want to do? In principle, it seems to be a simple task. The security agent wants to prevent the user from reading the machine name when calling "tm1web" and "pmpsvc" in the URL.
Therefore, he wants to invoke "tm1web" and "pmpsvc" with a portal name instead of the machine name. The exact explanation of all parameters is as follows:
Detailed description:
• First call from Client: https://[portalname]/tm1web
• Portal is translating the URL from https://[portalname]/tm1web to https://[machinename:9510]/tm1web
• Parameter in AppServer webcontent/bi => var planningServices = ["https://[portalname]"];
• Parameter in AppServer webcontent => var planningServices = ["https://[maschinename:9510]"];
• Parameter in CA Server webcontent => var planningServices = ["https://[maschinename:9510]"];
Problems we have:
Problem 01:
If we use this logic with pmpsvc then the call works with portalname / pmpsvc but if it comes back from checking the user (Appserver BI) it returns the URL to the machine name
Problem 02:
PMPSVC has the further problem that you can call it, but if you then try to start the application and TM1web should open, which again does not work because TM1Web is also searched with the machine name which is already wrong at this time, since we switched TM1Web to the portal name
I hope it is understandable so far and someone can tell me what is wrong or if this can ever work as we do here
Thanks Chris
Re: prevent the user from reading the machine name when calling "tm1web" and "pmpsvc"
You can change the hosts file on the users PCs. Assuming the security is quite locked down that could easily be done by IT en masse and the users wouldn’t be able to access the file to see the contents.
If you haven’t worked with a hosts file before it’s simple and just has an address for what you type and what the PC understands that to actually be (plus a comment if desired.)
Why not just create a DNS entry for your server and use that instead in all your links? That should hide the machine name as long as your DNS entry has the name you want to use. I see this all the time.
- Version: all Versions
- Excel Version: all Versions
Hi guys,
I do not understand how that should work with DNS or hosts. Both variants are called tm1web or pmpsvc.
I already understand that this will work, but when I open an application, then this looks my tm1web again with the hostname and not with the entry of a hosts or a DNS.
Or did I misunderstand you?
Chris
Chris
No, it will not. If you have a DNS entry like MyNewName.MyCompany.com, instead of TM1ServerName and open TM1Web with MyNewName.MyCompany.com:9510/tm1web/, instead of TM1ServerName:9510/tm1web/, then your URL will always stay on MyNewName.MyCompany.com. It will not revert back to TM1ServerName.
@tomok
ok, will this fix also my issue how application is calling tm1web?
and is it possible to set the same DNS twice for
MyNewName.MyCompany.com:9510/tm1web/ and MyNewName.MyCompany.com:9510/pmpsvc/
Chris
Ps.: thanks for helping me
Chris
I don't know what you are talking about.
Setting a DNS entry just serves as a substitute for the IP address. You can use that DNS entry everywhere you would use the server name (because believe it or not, on your network the server name is also an alias for the IP address).
