Alias update and stargate view
kenship
OLAP Product: Cognos
Version: Planning Analytics 2.0.7
Post by kenship »
I have a TI process that transfer data from input cube to report cube, it's run every 5 min.
I have another TI process that updates alias of a certain dimension every 10 min.
I have noticed that the time needed to execute the input to report cube process is significantly more after alias update process executes. I suspect the stargate view needs to be rebuilt.
My question is: is there any way to update the alias without interrupting the stargate view?
jim wood
Version: PA 2.0.7
Re: Alias update and stargate view
Post by jim wood »
I'm pretty certain that the system regards an alias change as meta change and would lock down the system. It may be taking longer as it will wait for any user activity to end before executing where as a data load (unless you're updating a dimension) will go in as a thread and will not halt user activity.
Shop at Amazon
kenship
Post by kenship »
I'm not sure at this time about user activity as there's only one user in the instance for now.
The alias update process takes 0.00s from start to finish so I believe this is not the problem.
But I noticed every time after the alias update process is run, the input to report cube process (which includes the dimension updated by the alias update process) takes much much more time to finish.
Thanks.
Kenneth
jim wood wrote: Tue Jan 16, 2018 5:38 pm I'm pretty certain that the system regards an alias change as meta change and would lock down the system. It may be taking longer as it will wait for any user activity to end before executing where as a data load (unless you're updating a dimension) will go in as a thread and will not halt user activity.
macsir
Version: PAL 2.0.9
Post by macsir »
Can you check if there is lock contention which is causing the delay?
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
I think updating an alias (like updating a rule) will purge all the affected stargates: rules use element aliases, so the calculated data may change after the "alias update".
You can turn ON the stargate logging and see how "alias changing" affects the stargates.
Sachin has described the stargate logging very well in his blog: https://everanalytics.wordpress.com/201 ... _deepdive/
TM1 and Data Science blog: 6th article - PAfE + VBA: Commit each cell without pressing “Commit” button.
kenship
Post by kenship »
Elessar wrote: Wed Jan 17, 2018 7:33 am I think updating an alias (like updating a rule) will purge all the affected stargates: rules use element aliases, so the calculated data may change after the "alias update".
This is useful, thanks. I guess this is something I have to live with.
