Good afternoon,
I am Needing help, I had a problem with system crash, after the error quoted in the topic, someone can help me as what this error would be.
It was after updating a dimension.
Thank you!
ERROR: Work unit operation failed due to lock error. Error code: 1
Thank you!
- Version: 10.2
- Steve Rowe
Re: Work unit operation failed due to lock error. Error code: 1
These kind of errors need to raised directly with IBM. Just in case you are not aware, this is an un official forum with no formal link to IBM.
In order to get IBM to investigate the crash you will need to get a reproducible test case together and crash dumps, together with a whole bunch of information about the version and environment you are operating in.
- Version: 10.2
Thanks for the info.
