Hello everybody!
I have a question about copying data from one element to another element in one cube using TI. I have a source, and a dim period, I need to copy data from one period to any other. It is necessary that when process start, I could choose the period in which to copy the data. how is this possible? Thank you!
Transfer data in the cube to a specific cell
- Version: PAW 2.0.8
- Excel Version: 2019
Re: Transfer data in the cube to a specific cell
Try this,It might help:
http://www.wimgielis.com/tm1_copydataonelement_EN.htm
http://www.tm1forum.com/viewtopic.php?t=1767 Thanks
- Version: 10.1
- Excel Version: 10
thanks for the info
but I do not quite understand what is meant MY_DIMENSION_VARIABLES_CHANGE_OVER_HERE and OTHER_DIMENSION_VARIABLES
(I'm sorry, I'm not completely versed in the processes)
IF(CELLISUPDATEABLE(vCubeName,
MY_DIMENSION_VARIABLES_CHANGE_OVER_HERE,
pTargetElement,OTHER_DIMENSION_VARIABLES)=1);
IF(VALUE_IS_STRING=0);
CELLPUTN(NValue,vCubeName,
pTargetElement,OTHER_DIMENSION_VARIABLES);
ELSE;
CELLPUTS(SValue,vCubeName,
ENDIF;
ENDIF;
ELSE;
ENDIF;
ENDIF;
- Version: PAL 2.0.9.18
Hello Wirt,
It means that you need to supply the correct arguments to the functions CellIsUpdateable, CellPutN, CellPutS, ...
This depends on your cube structure and it's only that can do this because you know the cube structure, the variables, and so on.
IBM Champion 2024
IBM Champion 2024
