Hi Guys,
Is there a free tool available to get a list of dependencies ( i.e. TM1 objects ) that are dependent on what are you targeting?
For example target cube A , has dependent dimensions A, B, C and D, and also has a Rule file
This rule file also points to other cubes etc. I would like to grab these objects as well + other associated processes.
What I want to be able to do is pass in the name of cube for example then call this script and punch out a file with
a list of dependent objects and then call 7zip to target this file and zip up the objects.
Any ideas?
Zark
TM1 Object dependency walker- get list of all dependent objects
BariAbdul
- Version: PAW 2.0.8
- Excel Version: 2019
Re: TM1 Object dependency walker- get list of all dependent objects
I don't know how much it going to help you ,but worth having a look at this thread:
http://www.tm1forum.com/viewtopic.php?f ... ram#p58483 Thanks
Drg
- OLAP Product: tm1
- Version: 10.2.0 - 10.3.0
I do not think that there are any real means to track the following dependencies(With the exception of staff resources that are not represented in any SDK):
Cube A
It is clear that very few people in the life so silently return, but met similar designs or design with a large nesting if(if(...).....if(...)).
Cube A
DB(
DB('Get cube for rule feeders',!a,!b,!c)
, !a
,!b
,!c
, !d
, if(!a@='true'
,'total'
,'subtotal')
, SUBST(
ATTRS( 'MEASURE'
, !e
DB('Get attribute name'
,!a
,!b
,!c)
, 4
, LONG(
ATTRS( 'MEASURE'
, !e
, DB('Get attribute name'
,!a
,!b
,!c)
) -4
7Zark7
- OLAP Product: TM1 and EV
- Version: 9.1 SP3
- Excel Version: Excel 2010
Thanks BariAbdul
Looks interesting. This might give me enough to work with. I suppose I better understand how perl works.
Zark
Zark
- tiagoblauth79
- OLAP Product: Cognos BI and TM1
- Excel Version: 10
tm1server.log registers cube dependencies at server startup. It might help you.
