The TABDIM function made useful
Version: PAL 2.0.9.18
Hello
TABDIM allows us to get the dimension names that make up a cube. Great.
But TABDIM remains the same, even if the cube dimension order gets reordered.
Can't we have an optional 3rd parameter that says:
- if 0 or omitted: give the same result as now, that is, TABDM following the original dimension order
- if 1 or all else except 0: give the result following the current dimension order
In that case we could check whether the s-type elements are currently in the last dimension.
Or am I missing something on this Saturday morning? :-)
IBM Champion 2024
Re: The TABDIM function made useful
I've yet to have the need to reorder my dimensions, so I can't comment extensively on the effects of doing so. But this seems to me to be a most beneficial suggestion for those who do.
I'd propose that such a change be done in tandem with the creation of a TabDimCount function which returns the number of dims in the cube to finally get rid of the ridiculous situation of having to do a loop of TabDims to find the first empty string.
Hi Alan
Me too, I very seldom reorder dimensions. It's just always good from the first time :-)
But AFAIK, you cannot know whether dimensions were reordered or not, on any given cube.
TabdimCount would be most useful too! And a shame it doesn't already exist. Everything in TM1 centers around cubes and dimension, and we cannot count them in an easy way!
IBM Champion 2024
