I'm encountering couple of issues when using OpsConsole to monitor TM1 Instances, would like to know if any one has faced the similar issues.
1. Can’t login to Ops Console when a Chore/process in running. Login will be successful only after completion of the chore/process.
2. Unable to Cancel a thread as the Admin access verification goes on lock/wait when a chore/process is running
3. Experiencing freezed webpage - OpsConsole while attempting to login - when TI is running on the system
Radhika
Operations Console - Issue
- Version: 10 2
- Excel Version: 2013
Re: Operations Console - Issue
I have exactly the same problem and cannot find a solution anywhere. Have you made any progress with this problem?
