CellIncrementN and BatchUpdate Mode
Post bug reports and the status of reported bugs
paulsimon
Version: 10.1.1 and 10.2.2
Post by paulsimon » Fri Jun 20, 2014 6:27 pm
I have just found an issue whereby CellIncrementN when you are in BatchUpdate Mode works like CellPutN
This is present in at least versions 10.2 IF1 and 10.2 FP1 IF1.
This has been reported to IBM.
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Re: CellIncrementN and BatchUpdate Mode
Post by Duncan P » Sun Jun 22, 2014 2:18 pm
I'm not sure that I would have accepted that as a bug if I had been IBM, given that the stated behaviour of BatchUpdateMode is that values written to cells are not available to the TI until the transaction is committed, so you would always be incrementing the value that was there at the start of the transaction.
Is that in fact what is happening? If the TI starts with a value in the cell, is the value at the end the last value applied or is it the sum of the original value and the last value applied?
mvaspal
OLAP Product: tm1
Version: 9 5 1 - 10 2 2 - 10.3 PA
Post by mvaspal » Fri Jun 27, 2014 8:44 am
I just wanted to report this bug to the forum when I saw Paul had already done so, I ran into this just today.
Why I would think this is a bug is that batch update mode works fine with the old logic:
vOldValue = CellGetN(...
CellPutN(Value + vOldValue , ...
I would expect the CellIncrementN should do the same.
Gabor
Version: [2.x ...] 11.0.3 / PAL 2.0.5
Excel Version: Excel 2010-2013
Post by Gabor » Fri Jun 27, 2014 9:46 am
I thought it is more or less the TI version of the deferred update in the GUI, a kind of ancestor of sandboxing giving a private version of a cube structure without consolidations & rules. N-element values should be accessible at that time.
