Processing Error
jinia
Version: abc
Excel Version: 2
Processing Error
Post by jinia » Fri Mar 13, 2009 8:37 am
I am getting the following status message while trying to process a cube in PROD.
"Finished building aggregations and indexes for measure group partition"
This screen is showing for 2days and the cube processing is not completing.
Can anybody help me in this topic.
Version: 9.5.2 64 bit moving to 10.2.2
Re: Processing Error
Post by Alan Kirk » Fri Mar 13, 2009 9:14 am
jinia wrote:I am getting the following status message while trying to process a cube in PROD.
Not in the OLAP Jobs forum, I think, unless you're looking to hire someone to sort it out for you?
Otherwise, it might be useful to indicate which OLAP tool you're using so that your message can be moved to the correct forum, and some users of that tool may be able to help you with an answer.
jinia
Version: abc
Excel Version: 2
Post by jinia » Fri Mar 13, 2009 10:13 am
I am using Sql server 2005 Analysis Services.
Post by Alan Kirk » Fri Mar 13, 2009 10:29 am
OK, I've moved the topic from OLAP Jobs to MS Analysis Services. This post (incorporating your question) should e-mail out to anyone who's subscribed to that forum.
belair22
Version: 9.5 9.4 9.1 9.0 8.4
Excel Version: 2007 2003
Post by belair22 » Thu Mar 19, 2009 6:09 am
If it hasn't finished after 2 days I'd guess there's something not quite right.
Cancel processing and 'undo' the most recent change you made (if you can remember what it was). If that's no help I'd suggest revewing your SSAS 'processing options'.
