Cognos TM1 consultant Permanent - Chennai , India
Posted: Wed Dec 28, 2016 6:11 am
by gpc1
This is regarding immediate requirement for Cognos TM1 professionals in Chennai, India.
Candidates presently from India only needed, Preferably from Chennai / South India.
Job Description:
• Extensive experience on Cognos TM1
• Provide solutions using Cognos TM1 for budgeting, planning and forecasting activities
• Strong OLAP experience; build cubes, dimensions, process and rules
• Cognos Planning/ Controller/Cognos BI experience preferable
• Deliver TM1 Solutions to a wide range of business areas.
• Implement complex Business Logic into TM1 Rules and increase performance by writing feeders.
• Use full TM1 suite of products, including TM1 Rules, Turbo Integrator Processes, Active Forms, API etc to deliver value to the business partners.
• Serve as a technical expert on TM1 and recommend ways to improve efficiency of current processes and models in TM1.
• Support and Installation and configuration of TM1 servers, Upgrading from TM1 9.5 to TM1 10.1/ 10.2 would be added advantage.
• Migrating TM1 data from Development to Production
• Using different data sources Like, TM1 cubes, Oracle/SQL server
• (DB2) database and MDX queries.
• Should have worked on at least one end to end development Project.
• Should be technically savvy in Turbo Integrators, TM1 Perspective, Rules and Feeders.
• Having experience in Cognos TM1 latest version with working experience in Performance Modeler will be an added advantage.
Experience : 6 to 10 years
Job Type: Full Time
Work Location :Chennai, India.
Contact : gpc@andreconsultancy.com.
