Having an issue getting the TM1 web interface to work with BI security. I have it working in TM1 10.1 but not under 10.2
I get a message that says 'The forward URL does not exist or it has failed validation. Ensure that a valid forward URL is specified.'
Under 10.1 you need to add the TM1 server name to the variables_tm1.xml file on the BI server. This does not work for 10.2
Has anyone had any experience getting BI security to work with TM 10.2 web interface.
I should also add that the other clients, i.e. perspectives work fine with BI security, just the web interface.
Brian
TM1 10.2 and BI security
- Version: 9.5.2
- Excel Version: 20120
Re: TM1 10.2 and BI security
http://www.tm1forum.com/viewtopic.php?f=3&t=9509 - servernames need to match the format setup elsewhere. There appears to be some match being tested (if it's FQDN on config, make it FQDN in the .xml file)
