Hi there,
I am using Cognos Express 10.1, I am trying to hide some subsets to users but unfortunately it seems not possible. I dont want them to change susbsets of the web views
Any tips ?
Subset Security with Planner/Contributor
Re: Subset Security with Planner/Contributor
Public subsets are not hideable. Elements from within a subset are subject to the security rights of the user but the subset itself is not. You can use private subsets but that will be a pain.
- Version: 9.5
- Excel Version: 2003
Not happy with that... nevermind Thanks Tomok
- Version: 9.5.2 FP3
Not sure exactly about your case, but:
Most of End Users will always have display of Control Objects set to False.
But if your view uses such subsets those should be visible there (hmm, would need to check to be 100% sure and am not able to do it now).
To create such subsets, easiest will be via TI (manual saving will not be allowed).
As tomok said, there is no security on subsets, but if you mean all users you could semi-hide them by creating those as Control Objects (name starts with }).Jonsulli wrote:I am trying to hide some subsets to users
As long as they do not have ADMIN rights to dimension (again, usually End Users do not) they will not be able to change public subsets anyway.Jonsulli wrote:I dont want them to change susbsets of the web views
- Version: 9.5
Thanks jstrygner, "}" could be a workaround.
You said :
You said :
Do you mean they will not be able to replace a subset by another or they will not be able to edit the subset ?As long as they do not have ADMIN rights to dimension (again, usually End Users do not) they will not be able to change public subsets anyway.
I meant they will not be able to edit the subset and by edit I meant modifying and re-saving it as public subset with the same name.Jonsulli wrote:Do you mean they will not be able to replace a subset by another or they will not be able to edit the subset ?
I need to admit I did not play around with Cognos Express, but I would assume if End Users are working with views, they will always be able to do slicing and dicing.
This means they can always shape the view as they want after initial opening, including modifying existing subsets by e.g. expanding a node or even choosing a different subset.
But (again, assuming they do not have proper ADMIN rights to modify views and/or subsets) they will not overwrite "initial" objects.
Every new re-opening of view will again come back to "initial" state saved by Admins.
I hope I got your question right
- Version: 9.5
Yes perfect ! Thanks jstrygner !I hope I got your question right
