View Extract with TM1 API
Hello all,
Did anyone have any success generating a view extract via the TM1 API ? I'm stuck !
I've built a valid handle to the extract object of a pre-existing view, but I can't return any data from TM1ViewExtractGetNext - it only returns a TM1 index type variable (value is 1). I think the sticking point is in the correct use of the TM1ViewExtractComparison property but can't be sure....
Any help appreciated.
Robin
Robin
Robin Mackenzie
Re: View Extract with TM1 API
Code attached ....
Option Explicit
Dim hUser As Long
Dim pPool As Long
Dim hServer As Long
Sub Test()
Dim hCube As Long
Dim hView As Long
Dim hExtract As Long
Dim hLines As Long
Call Login
hCube = TM1ObjectListHandleByNameGet(pPool, hServer, TM1ServerCubes, TM1ValString(pPool, "plan_BudgetPlan", 0))
hView = TM1ObjectListHandleByNameGet(pPool, hCube, TM1CubeViews, TM1ValString(pPool, "High Level Profit and Loss", 0))
hExtract = TM1ViewExtractCreate(pPool, hView)
TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractComparison, TM1ValIndex(pPool, 1)
TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractRealLimitA, TM1ValReal(pPool, 0)
TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractRealLimitB, TM1ValReal(pPool, 0)
TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractSkipConsolidatedValues, TM1ValBool(pPool, 0)
TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractSkipZeroes, TM1ValBool(pPool, 0)
TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractSkipRuleValues, TM1ValBool(pPool, 0)
TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractStringLimitA, TM1ValString(pPool, "", 0)
TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractStringLimitB, TM1ValString(pPool, "", 0)
hLines = TM1ViewExtractGetNext(pPool, hExtract)
Debug.Print TM1ValType(hUser, hLines)
TM1ViewExtractDestroy pPool, hExtract
Call Logoff
End Sub
Robin Mackenzie
Well, it seems like a good nights sleep will help any API problem...
Do
' do stuff with hLines
Loop Until hLines = 0
Robin Mackenzie
- Version: 9.5
any resolution for this? mine still return an index
- OLAP Product: MODLR - The CPM Cloud
- Version: Always the latest.
- Excel Version: 365
I have a C++ version of this I wrote to allow batch file cube exports to csv. Would you like me to post it or are you after VBA/6 only?
- Version: 9.5
you can post any language, C++ is fine with me.
Thank You
Thank You
I need to extract view using filter by an dimension (I have value of an element). I can get/create hView, but TM1ViewExtractCreate(TM1ViewExtractGetNext) extracts all contents of cube.
How can I set an filter? Should I create a new View with subsets?
- macsir
- Version: PAL 2.0.9
I would recommend to achieve this via REST API which is the future.
How can I select and insert at subset all elements of a dimension whose names match a regular expression?
It does not work:
It does not work:
TM1V vPattern = TM1ValString(hPool, Pattern, PatternLen);
TM1V vOk = TM1SubsetSelectByPattern(hPool, hNewSubset, vPattern,TM1ValBool(hPool, isSelect));
if (TM1ValType(hUser, vOk) == TM1ValTypeBool() && !TM1ValBoolGet(hUser,vOk)) {
throw ...;
vOk= TM1SubsetSelectionInsertChildren(hPool, hNewSubset);
throw ...;
I'd second this. As an example, using Marius Wirtz' TM1PY libraries:Re: View Extract with TM1 API
Unread post by macsir » Tue Oct 24, 2017 4:47 am
Create MDX View on }ClientGroups cube and query data through it.
IMPORTANT: MDX Views can not be seen through Architect/Perspectives.
import uuid
from TM1py.Objects import MDXView
from TM1py.Services import TM1Service
with TM1Service(address='localhost', port=12354, user='admin', password='apple', ssl=True) as tm1:
# Random text
random_string = str(uuid.uuid4())
# Create mdx view
mdx = "SELECT " \
"NON EMPTY {TM1SUBSETALL( [}Clients] )} on ROWS, " \
"NON EMPTY {TM1SUBSETALL( [}Groups] )} ON COLUMNS " \
"FROM [}ClientGroups]"
mdx_view = MDXView(cube_name='}ClientGroups', view_name='TM1py_' + random_string, MDX=mdx)
# Create mdx view on TM1 Server
tm1.cubes.views.create(view=mdx_view)
# Get view content
content = tm1.cubes.cells.get_view_content(cube_name=mdx_view.cube, view_name=mdx_view.name)
# Print content
print(content)
- macsir
Yes, that's good idea but basically TM1py is still built on rest api. If you are experienced with programming and want to learn things, better to start with rest api first. If wanting a quick thing, then TM1py is good choice.David Usherwood wrote: ↑Tue Oct 24, 2017 3:13 pmI'd second this. As an example, using Marius Wirtz' TM1PY libraries:Re: View Extract with TM1 API
I would recommend to achieve this via REST API which is the future.See more examples at https://github.com/cubewise-code/TM1py-samplesCode: Select all
""" Create MDX View on }ClientGroups cube and query data through it. IMPORTANT: MDX Views can not be seen through Architect/Perspectives. """ import uuid from TM1py.Objects import MDXView from TM1py.Services import TM1Service with TM1Service(address='localhost', port=12354, user='admin', password='apple', ssl=True) as tm1: # Random text random_string = str(uuid.uuid4()) # Create mdx view mdx = "SELECT " \ "NON EMPTY {TM1SUBSETALL( [}Clients] )} on ROWS, " \ "NON EMPTY {TM1SUBSETALL( [}Groups] )} ON COLUMNS " \ "FROM [}ClientGroups]" mdx_view = MDXView(cube_name='}ClientGroups', view_name='TM1py_' + random_string, MDX=mdx) # Create mdx view on TM1 Server tm1.cubes.views.create(view=mdx_view) # Get view content content = tm1.cubes.cells.get_view_content(cube_name=mdx_view.cube, view_name=mdx_view.name) # Print content print(content)
Absolutely. But you have to use some language to work with the REST API, and TM1PY does all the heavy lifting - and Python has all those juicy libraries to pull in to do things which you can't do with the native tools eg IRR (in numpy), remi (for web frontends), csv, xlwings (excel)... I have seen a SAP library but can't speak for it since I don't have SAP.Re: View Extract with TM1 API
by macsir » Tue Oct 24, 2017 11:38 pm
- macsir
I am planning to wrap rest api with JAVA and possibly publish it via github too.
What a good ideaI am planning to wrap rest api with JAVA and possibly publish it via github too.
Hubert Heijkers, who 'owns' the REST API, has some routines for Google's Go language, but when I last looked they weren't as comprehensive as TM1PY:
https://github.com/Hubert-Heijkers
- macsir
Thanks, David. Yes, I know Hubert and I will have a look what he has written to see what I can borrow from there.David Usherwood wrote: ↑Thu Oct 26, 2017 12:52 pmWhat a good ideaI am planning to wrap rest api with JAVA and possibly publish it via github too.
Thank you. It helps me with mdx-view. I can create a mdx-view, find it and use as regular (native) view. But I can not write mdx-query with restrict by subsets or another condition. For example, I write query:
The dimensuion [period] has values "2017.01.01", "2017.01.02", "2017.01.03",..,"2017.12.30" and "2017.12.31".
And I whant use filter like this:
to select from my mdx-view only data has [period] from "2017.03.01","2017.03.02","2017.03.03",.."2017.03.31".
How can I write this filter?
select
{[dim 1].MEMBERS}
* {[dim 2].Members}
* {[dim 3].Members}
* {[period].Members} on COLUMNS,
{[dim 4].MEMBERS }
* {[dim 5].MEMBERS} on ROWS
from
[cube A]
TM1FILTERBYPATTERN(TM1SUBSETALL([period]),"2017.03.*")
- macsir
You need WHERE clause after FROM.
This clause is known to me. And I try to use it like this:
However when I use:
TM1V hExtractList = TM1ViewExtractCreate(hPool, hObject)
and hExtract = TM1ViewExtractGetNext(hPool, hExtractList)
I upload all content of cube.
What am I doing wrong?
SELECT
{ TM1SUBSETALL([}Clients]) } ON COLUMNS,
{ TM1SUBSETALL([}Groups]) } ON ROWS
where ([}Clients].[Admin], [}Groups].[ADMIN])
Rest API:
POST on https://as-msk-a0134:8000/api/v1/Execut ... xpand=Axes($expand=Hierarchies($select=Name),Tuples($expand=Members($select=Name))),Cells
Headers:
Accept:text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
Content-Type:application/json; charset=utf-8
Accept-Encoding:gzip, deflate, br
Accept-Language:ru-RU,ru;q=0.8,en-US;q=0.6,en;q=0.4
Authorization:Basic YWRtaW46
Cache-Control:max-age=0
Connection:keep-alive
Cookie:TM1SessionId=pwbEILUfA0Q_OoHLmYC89w
DNT:1
Host:as-msk-a0134:8000
Upgrade-Insecure-Requests:1
User-Agent:Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36
Data:
{"MDX":"SELECT {TM1SUBSETALL([}Clients])} ON COLUMNS, {TM1SUBSETALL([}Groups])} ON ROWS FROM [}ClientGroups] where ([}Clients].[Admin],[}Groups].[ADMIN])"}
Response:
Headers:
DNT:1
Data:
Response:
"error": {
"code": "",
"message": "MDX parameter is required and cannot be empty."
- macsir
ture wrote: ↑Thu Nov 02, 2017 8:51 am This clause is known to me. And I try to use it like this:However when I use:Code: Select all
SELECT { TM1SUBSETALL([}Clients]) } ON COLUMNS, { TM1SUBSETALL([}Groups]) } ON ROWS FROM [}ClientGroups] where ([}Clients].[Admin], [}Groups].[ADMIN])
SELECT
{ [}Clients].[Admin] } ON COLUMNS,
{ [}Groups].[ADMIN] } ON ROWS
