View Extract with TM1 API
rmackenzie
Post by rmackenzie » Fri Jun 20, 2008 6:51 am
Hello all,
Did anyone have any success generating a view extract via the TM1 API ? I'm stuck !
I've built a valid handle to the extract object of a pre-existing view, but I can't return any data from TM1ViewExtractGetNext - it only returns a TM1 index type variable (value is 1). I think the sticking point is in the correct use of the TM1ViewExtractComparison property but can't be sure....
Any help appreciated.
Robin
Robin Mackenzie
rmackenzie
Re: View Extract with TM1 API
Post by rmackenzie » Fri Jun 20, 2008 7:08 am
Code attached ....
Option Explicit
Dim hUser As Long
Dim pPool As Long
Dim hServer As Long
Sub Test()
    Dim hCube As Long
    Dim hView As Long
    Dim hExtract As Long
    Dim hLines As Long
    Call Login
    hCube = TM1ObjectListHandleByNameGet(pPool, hServer, TM1ServerCubes, TM1ValString(pPool, "plan_BudgetPlan", 0))
    hView = TM1ObjectListHandleByNameGet(pPool, hCube, TM1CubeViews, TM1ValString(pPool, "High Level Profit and Loss", 0))
    hExtract = TM1ViewExtractCreate(pPool, hView)
    TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractComparison, TM1ValIndex(pPool, 1)
    TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractRealLimitA, TM1ValReal(pPool, 0)
    TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractRealLimitB, TM1ValReal(pPool, 0)
    TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractSkipConsolidatedValues, TM1ValBool(pPool, 0)
    TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractSkipZeroes, TM1ValBool(pPool, 0)
    TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractSkipRuleValues, TM1ValBool(pPool, 0)
    TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractStringLimitA, TM1ValString(pPool, "", 0)
    TM1ObjectPropertySet pPool, hExtract, TM1ViewExtractStringLimitB, TM1ValString(pPool, "", 0)
    hLines = TM1ViewExtractGetNext(pPool, hExtract)
    Debug.Print TM1ValType(hUser, hLines)
    TM1ViewExtractDestroy pPool, hExtract
    Call Logoff
End Sub
Robin Mackenzie
rmackenzie
Post by rmackenzie » Sat Jun 21, 2008 12:02 am
Well, it seems like a good nights sleep will help any API problem...
Do
    ' do stuff with hLines
Loop Until hLines = 0
Robin Mackenzie
olapuser
Version: 9.5
Post by olapuser » Tue Jul 12, 2011 10:47 am
any resolution for this? mine still return an index
Kyro
OLAP Product: IBM Cognos TM1 all the way!
Version: You name it.
Excel Version: 2003 -2007 -2010
Post by Kyro » Mon Jul 18, 2011 6:14 am
I have a C++ version of this I wrote to allow batch file cube exports to csv. Would you like me to post it or are you after VBA/6 only?
olapuser
Version: 9.5
Post by olapuser » Mon Jul 18, 2011 5:34 pm
you can post any language, C++ is fine with me.
Thank You
ture
OLAP Product: tm1
Post by ture » Mon Oct 23, 2017 9:28 am
I need to extract view using filter by an dimension (I have value of an element). I can get/create hView, but TM1ViewExtractCreate(TM1ViewExtractGetNext) extracts all contents of cube.
How can I set an filter? Should I create a new View with subsets?
macsir
OLAP Product: TM1, SSAS
Version: 9.5 - 10.2
Excel Version: 97 - 2013
Post by macsir » Tue Oct 24, 2017 4:47 am
I would recommend to achieve this via REST API which is the future.
ture
OLAP Product: tm1
Post by ture » Tue Oct 24, 2017 2:48 pm
How can I select and insert at subset all elements of a dimension whose names match a regular expression?
It does not work:
	TM1V vPattern = TM1ValString(hPool, Pattern, PatternLen);
	TM1V vOk = TM1SubsetSelectByPattern(hPool, hNewSubset, vPattern,TM1ValBool(hPool, isSelect));
	if (TM1ValType(hUser, vOk) == TM1ValTypeBool() && !TM1ValBoolGet(hUser,vOk)) {
		throw ...;
	vOk= TM1SubsetSelectionInsertChildren(hPool, hNewSubset);
		throw ...;
Post by David Usherwood » Tue Oct 24, 2017 3:13 pm
Unread post by macsir » Tue Oct 24, 2017 4:47 am
I'd second this. As an example, using Marius Wirtz' TM1PY libraries:
Create MDX View on }ClientGroups cube and query data through it.
IMPORTANT: MDX Views can not be seen through Architect/Perspectives.
import uuid
from TM1py.Objects import MDXView
from TM1py.Services import TM1Service
with TM1Service(address='localhost', port=12354, user='admin', password='apple', ssl=True) as tm1:
    # Random text
    random_string = str(uuid.uuid4())
    # Create mdx view
    mdx = "SELECT " \
          "NON EMPTY {TM1SUBSETALL( [}Clients] )} on ROWS, " \
          "NON EMPTY {TM1SUBSETALL( [}Groups] )} ON COLUMNS " \
          "FROM [}ClientGroups]"
    mdx_view = MDXView(cube_name='}ClientGroups', view_name='TM1py_' + random_string, MDX=mdx)
    # Create mdx view on TM1 Server
    tm1.cubes.views.create(view=mdx_view)
    # Get view content
    content = tm1.cubes.cells.get_view_content(cube_name=mdx_view.cube, view_name=mdx_view.name)
    # Print content
print(content)
See more examples at https://github.com/cubewise-code/TM1py-samples
macsir
Version: 9.5 - 10.2
Post by macsir » Tue Oct 24, 2017 11:38 pm
import uuid
    # Random text
    # Create mdx view
    mdx = "SELECT " \
    # Get view content
    # Print content
print(content)
Yes, that's good idea but basically TM1py is still built on rest api. If you are experienced with programming and want to learn things, better to start with rest api first. If wanting a quick thing, then TM1py is good choice. :D
Post by David Usherwood » Wed Oct 25, 2017 8:39 am
David Usherwood wrote: ↑
Absolutely. But you have to use some language to work with the REST API, and TM1PY does all the heavy lifting - and Python has all those juicy libraries to pull in to do things which you can't do with the native tools eg IRR (in numpy), remi (for web frontends), csv, xlwings (excel)... I have seen a SAP library but can't speak for it since I don't have SAP.
macsir
Version: 9.5 - 10.2
Post by macsir » Thu Oct 26, 2017 12:45 am
I am planning to wrap rest api with JAVA and possibly publish it via github too. :D
Post by David Usherwood » Thu Oct 26, 2017 12:52 pm
What a good idea :)
Hubert Heijkers, who 'owns' the REST API, has some routines for Google's Go language, but when I last looked they weren't as comprehensive as TM1PY:
https://github.com/Hubert-Heijkers
macsir
Version: 9.5 - 10.2
Post by macsir » Fri Oct 27, 2017 1:49 am
What a good idea :)
Thanks, David. Yes, I know Hubert and I will have a look what he has written to see what I can borrow from there. :D
ture
OLAP Product: tm1
Post by ture » Wed Nov 01, 2017 7:17 am
Thank you. It helps me with mdx-view. I can create a mdx-view, find it and use as regular (native) view. But I can not write mdx-query with restrict by subsets or another condition. For example, I write query:
select
   {[dim 1].MEMBERS}
   * {[dim 2].Members}
   * {[dim 3].Members}
   * {[period].Members}  on COLUMNS,
   {[dim 4].MEMBERS }
   * {[dim 5].MEMBERS}         on ROWS
from
   [cube A]
The dimensuion [period] has values "2017.01.01", "2017.01.02", "2017.01.03",..,"2017.12.30" and "2017.12.31".
And I whant use filter like this:
TM1FILTERBYPATTERN(TM1SUBSETALL([period]),"2017.03.*")
to select from my mdx-view only data has [period] from "2017.03.01","2017.03.02","2017.03.03",.."2017.03.31".
How can I write this filter?
macsir
Version: 9.5 - 10.2
Post by macsir » Thu Nov 02, 2017 4:42 am
You need WHERE clause after FROM.
ture
OLAP Product: tm1
Post by ture » Thu Nov 02, 2017 8:51 am
This clause is known to me. And I try to use it like this:
SELECT
       { TM1SUBSETALL([}Clients]) }  ON COLUMNS,
       { TM1SUBSETALL([}Groups])  }  ON ROWS
where ([}Clients].[Admin], [}Groups].[ADMIN])
However when I use:
TM1V hExtractList = TM1ViewExtractCreate(hPool, hObject)
and hExtract = TM1ViewExtractGetNext(hPool, hExtractList)
I upload all content of cube.
What am I doing wrong?
ture
OLAP Product: tm1
Post by ture » Thu Nov 02, 2017 9:12 am
Rest API:
POST on https://as-msk-a0134:8000/api/v1/Execut ... xpand=Axes($expand=Hierarchies($select=Name),Tuples($expand=Members($select=Name))),Cells
Headers:
Accept:text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
Content-Type:application/json; charset=utf-8
Accept-Encoding:gzip, deflate, br
Accept-Language:ru-RU,ru;q=0.8,en-US;q=0.6,en;q=0.4
Authorization:Basic YWRtaW46
Cache-Control:max-age=0
Connection:keep-alive
Cookie:TM1SessionId=pwbEILUfA0Q_OoHLmYC89w
DNT:1
Host:as-msk-a0134:8000
Upgrade-Insecure-Requests:1
User-Agent:Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36
Data:
{"MDX":"SELECT {TM1SUBSETALL([}Clients])} ON COLUMNS, {TM1SUBSETALL([}Groups])} ON ROWS FROM [}ClientGroups] where ([}Clients].[Admin],[}Groups].[ADMIN])"}
Response:
    "error": {
        "code": "",
        "message": "MDX parameter is required and cannot be empty."
macsir
Version: 9.5 - 10.2
Post by macsir » Fri Nov 03, 2017 1:32 am
SELECT
However when I use:
SELECT
       { [}Clients].[Admin] }  ON COLUMNS,
       { [}Groups].[ADMIN]  }  ON ROWS
