Hi Ekspertos.
Just want to ask if Alpha server machine can use the content store that the Bravo server uses?
Without deleting the contents of the content store.
Without creating new tables that will act as content store.
Is it possible?
Thanks.
Can two server machines use single Content Store
- Version: 10.2.2.x
- Version: 10.2.2.x
Re: Can two server machines use single Content Store
This is the content store that I'm trying to reuse in my Bravo server.
- Content Store for two Servers.png (13.76 KiB) Viewed 3481 times
- Version: 9.5.2
You can have mutiple content managers (purely from a fail over scenario) so technically you should be able to do that. I would however strongly recommend you read help files on content manager configuration end to end on how to configure it (this is for Version 10). And obviously take a backup of your content manager database before proceeding.
http://pic.dhe.ibm.com/infocenter/cbi/v ... figCM.html
Jan
Jan
- Version: 10.2.2.x
Thanks for the answer Jan.
