I have encountered an issue that is a show stopper for us going live with TM1 9.4 MR1. I consider this a bug as it does not manifest itself in TM1 9.0 SP3 and it may affect you.
The issue is when our intraday chore (runs every 10 minutes) runs into our overnight chore (runs at 6am every morning) Because the overnight chore take 20 minutes, the usual scenario is for the intraday to wait until the overnight chore has finished before starting. This does not happen in TM1 9.4 MR1.
TM1 9.4 MR1 runs the intraday chore BEFORE the overnight one is finished. Which buggers up everything and crashes the TM1 server.
...and I get left with a blooming }CubeProperties.cub$
In fact the last listed process (of overnight chore) is a savedataall, but this is never runs.
It could just be our system here, or could be that Cognos has changed the way Savedataall works or decided that chores should interfere with each other, but it's dam annoying.
I have also attached a word doco that I sent to Cognos support. This will give you a more detailed description of what is going on.
Any advice would be very welcomed.
Ken
TM1 9.4 MR1 Crash when chores queue up
- TM1 9.4 MR1 bug.doc
- (287 KiB) Downloaded 318 times
Re: TM1 9.4 MR1 Crash when chores queue up
... disappointing as I thought they sorted this issue out in 9.1.4
This might be a kludgy workaround but no reason why it wouldn't work. Have a control cube that lists by time blocks and days of the week when your intra day chore should run, check on the prolog of the first process whether the intraday chore should run or quit. This should be easy to implement and no reason why it shouldn't work.
Ken, I'm back from the Middle East on Monday (actually I'm in Amsterdam now - long story) and will call you then to discuss possible solutions/workrounds.
Make your daily process declare and set a user variable to 1 when it runs and 0 when it finishes.
Your 10 minute process can check this user variable to see if the daily process is currently running and quit accordingly.
Thanks for that.
I will probably use the flagging method (in one of the lookup cubes) and then get the chores to reference that before executing.
I am still going to get IBM\Cognos to give me an answer, especially now that I realised that it was a bug in 9.1.
Can anyone confirm what version of 9.1 this bug was fixed?
Ken
Ken
- Alan Kirk
SP4.Ken Vuong wrote:Thanks for that.
