CubeAction=1511
holger_b
CubeAction=1511
Post by holger_b »
Today, I noticed for the first time that when you open a .pro file in an editor outside of TM1, you will see the following line fairly at the end:
CubeAction=1511DataAction=1503CubeLogChanges=0
Does anybody know what the sense of this is?
Thank you
Holger
Marcus Scherer
Re: CubeAction=1511
Post by Marcus Scherer »
CubeAction=1511 means "No Action", DataAction 1503 means "Store Values", Enable cube logging turned off.
The values correspond to settings in the "Cube" tab of the TI wizard, in this case it is the default setting.
Since you didn't specify a cube there you can ignore it. If you make changes there you will see that the values will change in the *.pro file.
holger_b
Re: CubeAction=1511
Post by holger_b »
Okay, I see... Thank you!
Holger
