I want to publish the data from a cube to Orcale database and i am using Planning Sample model given by IBM.
I am using TI process to accomplish it. The problem i face here is, the data is not getting published in the tables. Below are the steps i follow,
1. DataSource as TM1 Cube View
2. Declare the variables and 'Others' in contents columns except for the variable which holds the data(in this case 'Value').
3. Prolog Tab
ODBCOpen('TM1_REPORT','Admin' ,'Admin');
4. Data Tab
ODBCOutput('TM1_REPORT',Expand('INSERT INTO plan_report(plan_business_unit,plan_department,plan_chart_of_accounts,plan_exchange_rates,plan_report,plan
_time,Value)' | ' VALUES("%v1%","%v2%","%v3%","%v4%","%v5%","%v6%",%Value%)'));
5. Epilog
ODBCClose('TM1_REPORT');
The process gets executed successfully without any warnings or errors but when i check for the table there is no data.
And i even tried to create a table using 'CREATE TABLE' command but it didnt work. In this case when i check it in the database, even the table doesnt exist.
Kindly suggest on this.
Thanks in advance.
Venki
Unable to Publish Data from cubes to Orcale database
Venki@1688
- Version: TM1 9.5.1
asutcliffe
- Version: 9.4.1 - 10.1
Re: Unable to Publish Data from cubes to Orcale database
Have you verified that there's data in your datasource and that the data tab is actually getting executed? You can do some simple debugging using asciioutput.
AnthonyT
- OLAP Product: TM1, EV
- Version: 9.0 9.1 9.4 9.5 10.1 10.2
- Excel Version: 2003 2007 2010 2015
I would try checking your variables first - are V1, V2 what you expect? Are they the correct format for where they are going to end up?
Also, try using the existing SQL statement but get rid of the EXPAND, and hardcode the variables - just to check that what you have written works
Anthony
That's no moon - that's a space station
- paulsimon
- Version: PA 2.0.5
I would put your SQL into a variable and do an ASCIIOUTPUT of that, then paste your SQL into the Oracle SQL Editor and run it under the same user to check that it works, and there are no permissions issues etc
