Hi All
Have you ever run 9.1 x64 on Windows 2008 server? I see only one post on the forum and that does not refer to whether it is 32 or 64 bit. (There is alot of posts regarding tm1web, so i assume x64 server is compatible with 2008)
I have successfully installed the 32 bit, but the 64 bit just closes the wizard immediately after selecting install and says that it has failed. There is also no log file available. I am trying to install 9.1 SP4.
Any advice would be appreciated.
Janro
9.1 x64 on Windows server 2008
- Version: 9.1 SP4
- Excel Version: 2003 SP3
Re: 9.1 x64 on Windows server 2008
I have had a problem installing TM1 9.4 (64 bit) on Windows 2008, if i choose TM1 web installation. During the installation, the installaer just rolls back by itself.
Then it was confirmed by Cognos that TM1 is not supported yet for Windows 2008. I guess because Windows 2008 comes with IIS 7. So we ended up installing the TM1 9.4 (64 bit) Wen on Windows 2003 and it worked fine
Andre
Andre
- Martin Ryan
Just had a thought Janro, - maybe try selecting "Tm1 Web", then do a custom install and alter it, so you're not installing TM1 Web, but whatever it is you want to install.
This worked for me on a 9.4 MR1 install.
