I'm trying to understand the purpose of the Quote Char field in a TI process as I have deleted the " character to avoid errors loading some source data containing ". This has worked - no error log was created, but I'm worried I may be creating another problem by doing this.
I have little influence over the source data as it is managed by the Micros point of sale team. They want to see Pizza Hawaii 11" and Pizza Veg 11" on the sales docket.
What is the purpose of "Quote Char" in TI data source?
- wilsonric
- Version: 2.0.9
- Excel Version: 365 MSO 16-0-13127
Richard
Richard
Re: What is the purpose of "Quote Char" in TI data source?
The quote char tells TI which characters surround a string to indicate that it's a complete string. This is sometimes needed when characters which are otherwise delimiters can be embedded in your fields.wilsonric wrote:I'm trying to understand the purpose of the Quote Char field in a TI process as I have deleted the " character to avoid errors loading some source data containing ". This has worked - no error log was created, but I'm worried I may be creating another problem by doing this.
Suppose that your source is a comma delimited file. The first record might be:
100,Product A,Jan 10But suppose that the next line is:
100,Product A, Deluxe Edition,Jan 10So instead the export program will probably output the row as (say):
100,"Product A, Deluxe Edition",Jan 10In addition, TI will skip the quote characters when it reads the field. It will see the field as Product A, Deluxe Edition without quotes on either end.
However when the quote character is a legitimate part of a field content (as is the case with your data) you shouldn't use it as the quote character (as you've found). You either clear it in the GUI, or set a different character (or no character) via the DatasourceASCIIQuoteCharacter variable in the Prolog.
Provided that there aren't any delimiters that are likely to be embedded in your data fields, that won't be a problem. If there will be, you need to use a different quote character. (Though this will also involve modifying the source data.) Indeed in such cases you may be better off switching from a character delimited format to a fixed width format, even though the latter is a bit of a pain to set up.
