Hello Everybody.
how do you achieve this by rules in the 2nd Cube ?
In the 2nd cube, 25000 is the sum of line 1 and 3 in the 1st and 4000 is line 2
Thx in advance
Lookup
- Version: 9.5.2
- Excel Version: 2003-2007
Re: Lookup
I would approach this as follows:
Workings cube dimensioned by
Budget Detail
Categorie Frais
Lignes
and the 'unit' dimension you have on the page
In this cube, a rule on the lines of
[''Montant Detail'] = n:
if(
DB('<source cube>,'Categorie',!Unit,!Lignes) @= !Categorie Frais,
DB('<source cube>,'Montant',!Unit,!Lignes),
#else
0);
Then the total for all !Lignes should be the figure you want. You'll need to get the feeders working too of course.
A comment - I'm inferring from your naming conventions that you are from the EP world. Welcome, and I hope we can help you make the transition. I've worked with both tools and I take the view that they both have their place. We've built an integration module which (mostly seamlessly) links EP published databases to TM1 - it was interesting to do.
InfoCat
Budget Detail
Categorie Frais
Lignes
if(
#else
0);
InfoCat
- Steve Rowe
Re: Lookup
As a side point how does the information get into cube 1?
A more traditional approach with this type of relational data would be to process the data into cube 2 using a TI process.
- Version: 9.5.2
Re: Lookup
Thank you for your answers
Finally, I've done that ...
David,
Yes we are from EP world. We are currently building process for integration between Analyst/Contributor and TM1. Do you have some example to help us ?
Thank you
David,
Thank you
