Any suggestions for this, i am getting an error during the installation.
Please find the attachment.
Thanks and regards
Cognos Express Installation
- OLAP Product: IBM COGNOS TM1
- Version: 9.5
- Express_Installation Error..png (240.88 KiB) Viewed 2271 times
- OLAP Product: Tm1
Re: Cognos Express Installation
Hi. I've encountered this when CX had been installed and removed - seems to retain the content store settings. Try the following command line entries (might be worth making a backup of the server in case something goes terribly wrong). Once you run these commands you should be able to install CX without the error message popping up).
reg delete HKEY_LOCAL_MACHINE\SOFTWARE\Informix\DBMS /F
reg delete HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Informix\DBMS /F
reg delete HKEY_LOCAL_MACHINE\SOFTWARE\Informix\Online\cm_ids_svr_custom /F
reg delete HKEY_LOCAL_MACHINE\SOFTWARE\Informix\SQLHOSTS\cm_ids_svr_custom /F
reg delete HKEY_LOCAL_MACHINE\SOFTWARE\Informix\SQLHOSTS\cm_ids_svr_custom_drda /F
reg delete HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Informix\Online\cm_ids_svr_custom /F
reg delete HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Informix\SQLHOSTS\cm_ids_svr_custom /F
reg delete HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Informix\SQLHOSTS\cm_ids_svr_custom_drda /F
net user informix /delete
J.Rizk
Tm1 for everyone
Tm1 for everyone
- Version: 9.5
thank you,
it is done.
it is done.
