Use Active Form but found duplicate Hierachy
tsureerat
Version: 9.5.2
Post by tsureerat »
We use TM1 9.5.2 with Excel 2010 and 2007. We prepare a report used Active Form and put the file in TM1 application . However, we found out that when we opened it from the perspective, it showed duplicated hieracy such as
Total current Asset 500
Cash on hand 100
AR 30
Input Vat 20
Cash on hand 100
AR 30
Input Vat 20
Data itself is correct. We deleted the duplicate hierachy in excel and saved. But when we opened it again, it happened again
Do you have any idea, how we can fix it
Neil Watson
Version: 6 and 2.5 to 10.2.2
Excel Version: 2007 2010
Re: Use Active Form but found duplicate Hierachy
Post by Neil Watson »
Hi there,
When you save you saved, did you first use the Active form option from the ribbon of "Rebuild Current Book", this will rebuild and redefine the ranges and formula for the Active form.
Secondly, there is a hidden sheet called "AR01" which holds the row information, if the hierarchy had become duplicated on this, then it would cause confusion on the active form itself.
Good luck
Neil
vaneagle
OLAP Product: Cognos Express and TM1
Version: 9.4 to 10.2
Excel Version: Excel 02 to 10
Post by vaneagle »
Neil Watson wrote:Hi there,
Good luck
Neil
I find when using active forms its best to drive column and row dimensions via subsets as this removes the hidden '{AR01}' related issues.
It gives more flexibility as well ;)
Kris W
Version: 9 10
Excel Version: 2003 2007
Post by Kris W »
I have encountered the same issue. The report rows do use subsets, and I have recreated a new active form which is identical to the original active form which is duplicating. The new active form works perfectly fine and does not duplicate. Has anyone found a definitive cause for this? Using 9.5.2 and Excel 2007.
Thanks in advance!
st2000
OLAP Product: TM1 (Windows) & SSAS 2014 Ent.
Version: 10.2.0 FP3
Excel Version: Excel 2013
Post by st2000 »
I encounter also to this problem, and also to an TM1RPTROW-Formula, which doesn't resolve the subset in Perspectives, but later in TM1Web it does.
My version indeed is 10.2.0 FP3 and my Excel is 2013 (for development clientside) resp. 2010 (on the server). Here the appearence:
I deleted all left {AR}xy sheets hidden from development, as actually all TM1RPTROW-formulas are driven by a named subset (Sprache means language and refers an Alias, which works as all labels are correctly in german):
=TM1RPTROW(ViewBlock4;"Servername:DIM_KPI";"Block4";"";Sprache;0)
(this one appears empty above, "-")
=TM1RPTROW(ViewBlock5;"Servername:DIM_KPI";"Block5";"";Sprache;0)
(this one appears with it's duplicated hierarchy below; which is not found similarly in the subset itself)
Also I tried "rebuild the workbook" and "rebuild the sheet" in the TM1/Active Report - menu.
I found only the older postings above about this error, but nothing newer. Is there a known best practice I could have missed?
Stefan
st2000 wrote: Thu Sep 07, 2017 6:31 pm I encounter also to this problem, and also to an TM1RPTROW-Formula, which doesn't resolve the subset in Perspectives, but later in TM1Web it does.
Have you deleted all rows under the top row (which contains the TM1rptrow formula before saving the sheet?
This is considered best practice as; in addition to improving performance upon opening - if not done you can end up with leftover rows that are technically under the active form and no longer attached to it.
st2000
Version: 10.2.0 FP3
Post by st2000 »
Declan, thank you very much.
Simple and helpful, it is back in the desired condition regarding the duplicates. The missing headline "-" stays, but is filled in TM1web, which is the important thing.
Stefan
rafaewolie
OLAP Product: IBM Cognos TM1
Version: TM1 PA 2.0
Post by rafaewolie »
I've tried everything that You suggested here, by the way I wrote it on another post last week, and nothing helped.
I changed the MDX, I'm not using that AR stuff, or Subset (Static or Dinamic), I cleaned all the rows below TM1RPTROW, and nothing works.
In Excel It seems working pretty good, but When published to TM1Web, the rows drilled from another Row duplicate always!
Somebody can Help Me?
AmbPin
Version: 9.5.2
Excel Version: 2007-10
Post by AmbPin »
I have seen this happen quite a few times and it is almost alway cured by deleting all of the workbook rows below the TM1Report row.
Can you rebuild your report from scratch to see if the problem happens in a second attempt. I do wonder sometimes if some corruption gets included into the Excel file and it is sometimes better to start again.
rafaewolie
Version: TM1 PA 2.0
AmbPin,
Thanks for Your help, but in my case, I did that, but Doesn't Work.
See the other post: http://www.tm1forum.com/viewtopic.php?f=3&t=13563
Thanks.
