hi ,
ViewZeroOut( 'plan_BudgetPlan', 'Budget Input Detailed' ); it sets all data points in the 'Budget Input Detailed' view to zero and as well plan_BudgetPlan cube also. if it is correct , default view of 'plan_BudgetPlan' Cube and 'Budget Input Detailed' view to zero .
but some of views under 'plan_BudgetPlan' cube are having data.
and the second question is : same ViewZeroOut function is used for the view of another cube. prossesed succusfully, but the view of the cube is having the data.
can any one clarify with possible reasons?
viewzeroout
- OLAP Product: tm1
- Version: 10.2
- Alan Kirk
Re: viewzeroout
Sounds reasonable.guntupalli wrote:ViewZeroOut( 'plan_BudgetPlan', 'Budget Input Detailed' ); it sets all data points in the 'Budget Input Detailed' view to zero
Doesn't sound reasonable, unless the Budget Input Detailed view covers all element combinations in the cube. Which, from the view name, seems unlikely.guntupalli wrote:and as well plan_BudgetPlan cube also.
The help is quite clear about this:
(My emphasis.) It does not zero out the whole cube unless that view represents all of the data in the cube.This function sets all data points in a view to zero.
Same answer. It clears a view, not a cube. If you want to clear all entered values, use CubeClearData instead.guntupalli wrote:if it is correct , default view of 'plan_BudgetPlan' Cube and 'Budget Input Detailed' view to zero .
(Though even that won't work if some of the values are rules-based, and pulled from another cube.)
- Martin Ryan
- Version: 10.1
Re: viewzeroout
It also won't clear out rule calculated values (unless the cells that the calculations rely on have been cleared out).
Martin
Martin
Jodi Ryan Family Lawyer
- Alan Kirk
Re: viewzeroout
Hence me mentioning that in the last paragraph...Martin Ryan wrote:It also won't clear out rule calculated values (unless the cells that the calculations rely on have been cleared out).
Martin
- Martin Ryan
- Version: 10.1
Re: viewzeroout
Ah, was skim reading and skipped the parentheses.
