I am currently working with a 64 bit version of TM19.5.1 and I am having difficulty writing a Ti process to create a Hierarchy that conditionally assigns an alias:
My Hierarchy goes like this
Vertical
|__> AOR1
|_> AOR2
|_> AOR3
|_>Expense Center
I was trying to write a TI process that would allow me to create a single alias that would be different for each level of the hierarchy. Essentially, the alias would need to incorporate the Aor- expense center. I had to create a unique element by concatenating the vertical-aor-expense center because the source file had a data issue of one aor being the child of two aors.
any help will be appreciated .
Resolving Hierarchy issue
jydell
- OLAP Product: tm1
- Version: TM1 Build Number: 11.8.01300.
- Excel Version: Version 2401
Re: Resolving Hierarchy issue
Not sure of your question but here are some functions that may assist
if you require a function to return the parent element try the "ELPAR" function this returns the parent of an element in a specified dimension
or "ELLEV" function returns the level of an element within a dimension (if you just want the level).
Remembering an alias cannot be repeated in a dimension.
A example of the elements and what you actually require the alias to look like would be helpful. (ie AOR1 requires alias "AOR2-AOR1" alias determined based on its parent etc)
- Michel Zijlema
- OLAP Product: TM1, PALO
If you want to load the same AOR code against multiple elements you should use a text attribute instead of an alias.JGARF wrote: I was trying to write a TI process that would allow me to create a single alias that would be different for each level of the hierarchy. Essentially, the alias would need to incorporate the Aor- expense center. I had to create a unique element by concatenating the vertical-aor-expense center because the source file had a data issue of one aor being the child of two aors.
Michel
