Unable to Register view
- Version: 9.5.2
- Excel Version: 2003
I am getting an error in the Message log when I run the chore consisting several processes.
'Error: Prolog procedure line (16) : unable to register view'
This error is in the process intialising and destroying view. Line 16 in the prolog procedure is Viewcreate(cubeName,viewname).
Could anybody have any idea?
regards,
Abi
regards,
Abi
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: Unable to Register view
I assume you get this message because you're trying to create a view that already exists. If you want to recreate the view use ViewDestroy followed by ViewCreate.
Michel
Michel
- Version: 9.5.2
I am just trying to update the cube by running the chore. Everytime time you run the process it will be created and destroyed ?Michel Zijlema wrote:Hi,
Michel
- Michel Zijlema
If recreating the view is part of the cube update process, than yes, the view will be recreated every time you run the chore.Abinaya wrote: I am just trying to update the cube by running the chore. Everytime time you run the process it will be created and destroyed ?
Are you creating the view as a datasource to another process or as a ZeroOut view or for other reasons?
Michel
- Version: 9.5.2
As part of zeroout view. because the error log is coming in the zero Out process.Michel Zijlema wrote:If recreating the view is part of the cube update process, than yes, the view will be recreated every time you run the chore.Abinaya wrote: I am just trying to update the cube by running the chore. Everytime time you run the process it will be created and destroyed ?
Michel
- Michel Zijlema
Basic question still is: is the view you try to create destroyed before creation? If not, then this is the cause of your error message - the reason being that you're trying to create a view that already exists.
Michel
Michel
- Version: 9.5 9.5.1 9.5.2
Hi Abi,Michel Zijlema wrote:Basic question still is: is the view you try to create destroyed before creation? If not, then this is the cause of your error message - the reason being that you're trying to create a view that already exists.
Michel
To complete Michel's argument, try
IF (ViewExists(CUBENameBlabla, ViewNameBlabla) = 1);
ViewDestroy(CUBENameBlabla, ViewNameBlabla) ;
ENDIF;
ViewCreate(CUBENameBlabla, ViewNameBlabla) ;
Cheers!
Claude.
Cheers!
Claude-Sebastien Jean
Senior Consultant in Information Technology
Keyrus Canada
www.keyrus.ca
Keyrus Canada
www.keyrus.ca
- Version: 9.5.2
thanks. It solved the problem.
You can simplify this a little. ViewDestroy doesn't error if the view doesn't exist so you don't need the if test.
- Excel Version: 2013
I just ran into an error on Planning Analytics local 2.0.2 IF4:
Unable to register view "<1>" in cube "<2>"
I tried a few different things; in the end I believe the error was caused by the length of my view name. I was making the view name unique by appending parameters, which normally isn't a problem, however this particular TI process takes enough parameters to be an issue. I have instead made it unique by appending a timestamp.
- orlando
- Version: PAL 2.0.8
that might be a problem of the windows max path lengthscjshown wrote: ↑Tue Dec 19, 2017 10:09 pm I just ran into an error on Planning Analytics local 2.0.2 IF4:
https://msdn.microsoft.com/en-us/librar ... px#maxpath
- wilsonric
- Version: 2.0.9
- Excel Version: 365 MSO 16-0-13127
Error: Prolog procedure line (110): Unable to register view "<1>" in cube "<2>"
We have found that another process (or even the same process) is currently using that view.
For example we have a process that updates our GL cube.
At monthend the accountants are loading journals into the ERP system, then running the GL cube update process to upload data from the ERP to the GL cube.
The accounting team have access to this upload process, so they often try and run it at the same time, resulting in this error.
They would not agree to limiting access to this upload process, so our work around was to install TM1 Top on all their machines, so they can reference this at monthend.
The error still occurs (less than before) but at least we can tell them to keep an eye on TM1 Top.
Richard
Richard
- orlando
Thanks for the reply - after three years
Then the process can run happily in parallel.
best regards,
see you in three years
orlando
Why don't you make the name of the view dynamic - e.g. with a timestamp or the name of the user who starts the process?wilsonric wrote: ↑Wed Feb 03, 2021 1:08 am The accounting team have access to this upload process, so they often try and run it at the same time, resulting in this error.
best regards,
orlando
