Is there a way through TI code to disable/enable a chore??
Automatic Chore Disabling
- Renaud MARTIAL
Re: Automatic Chore Disabling
There's no TI instruction to enable or disable a Chore.
However, you can simulate this function by:
- adding a Numeric Attribute 'disabled' to the '}chores' dimension
- creating a process (with a parameter giving the chore name) that checks if the attribute 'disabled' is = 1 for this chore
If the answer is Yes, call the 'choreQuit()' instruction.
- Add this process as the first one to be executed by your chores.
You can then control the execution of chores by setting a value of 1 as 'disables' attribute.
Hope it helps,
Renaud.
Hope it helps,
Renaud.
- Steve Vincent
- Version: 10.2.2 FP1
its already being talked about as an enhancement request in here
