TM1 9.0 Sp3 Disappearing Dimension Editor
IanK
Post by IanK »
a Client is running a Perspectives version of TM1 9.0 Sp3, the program has been working fine up untill a week ago. Now when the user opens her Dimension Editor it appears to open it and then hides it somewhere!
I have tried re-installing TM1, re-installing Office, replaced the Tm1p.ini file. done a rollback of the machine and nothing seems to work.
Any advice would be greatly appreciated.
Ian
Martin Ryan
Re: TM1 9.0 Sp3 Disappearing Dimension Editor
Post by Martin Ryan »
Have you replaced all the tm1p.ini files? There's several. Search out all the .ini files on her C:\ and replace them all.
Martin
Jodi Ryan Family Lawyer
Paul Segal
Version: TM1 11 and up
Post by Paul Segal »
Also, is she working on a laptop and had it connected to an external monitor?
Paul
Ivan Cepero
Post by Ivan Cepero »
I had the same thing happen when I logged in after I used an external monitor.
To solve on a single monitor, I followed these steps:
Click on Alt + space
Press M
Use arrow keys to move
paulsimon
Version: PA 2.0.5
Post by paulsimon »
Ian
I would try the previous suggestions first, but if all else fails then delete the subed.tbd file that you will find under Documents and Settings\Application Data\<User Id>\Applix\TM1
(It struck me as a little odd that this is still under Applix given that I am running 9.1 SP3 and everything else seems to be Cognos. However, for you, on 9.0, it will still be Applix.)
This file will get automatically recreated. It holds various settings related to the subset editor and one of those might have got corrupted.
IanK
Post by IanK »
Hi Gents,
I finally resolved the issue with all your help, she connected her machine to a proxy last week thursday. So that is how the issue occured!
Much appreciated.
Ian
