I calculated a large view that took 3 minutes to calculate, then close Server Explorer, Excel, etc...then went through the view again one hour later and took a few seconds.
Then I came back a couple of days later and took 3 minutes or more to be calculated.
For how long a view is stored in memory??
thanks
View in memory duration
- John Hobson
- OLAP Product: Any
- Version: 1.0
- Excel Version: 2020
Re: View in memory duration
Armas
The cached values get discarded if a change occurs in the underlying data - this can be 1 second or 1 week.
I don't think there is any automatic recycling of the cache, although it can be a good idea to do this manually once in a while
John Hobson
The Planning Factory
- Steve Vincent
- Version: 10.2.2 FP1
Just to clarify that, a "change" includes;
- Editing of a rule
Change of data
Change of elements
- Olivier
- Version: Tm1 10.2.2fp4 -> 2.09
- Excel Version: Excel 2013 - 2019
John,
What actions are you refering to when you talk about refreshing manually the cache ?
Olivier
John,
Olivier
HTH
Olivier
Olivier
- John Hobson
- OLAP Product: Any
- Version: 1.0
I was really talking about restarting the server so that you start off with an empty cache again.
J
J
John Hobson
