Export Cube ViewTo Excel/CSV
vinnusea
Post by vinnusea » Mon Sep 27, 2010 5:24 pm
What script i need to write to export the cube view to Excel or CSV and this process should be added in chores. And where to write??.....
Thanks for your time.
Vinnusea
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Re: Export Cube ViewTo Excel/CSV
Post by rkaif » Mon Sep 27, 2010 6:02 pm
You can use ASCIIOutput() function to export data to CSV file
Crate a TI Process
Data Source tab: Use the Cube View as the Data Source
Variable tab: declare all the variables as Other
Advanced -> Data tab: use ASCIIOutput function to export the data to CSV file
Hope that helps!
Cheers!
Rizwan Kaif
vinnusea
Post by vinnusea » Mon Sep 27, 2010 6:05 pm
Thank you soo much.... for the reply
Vinnusea
vinnusea
Post by vinnusea » Mon Sep 27, 2010 7:24 pm
ASCIIOUTPUT('C:\Documents and Settings\preeth\Desktop\TEST11.cma', v1, v2, v3, v4, v5, v6 );
I took TM1 Cube view as source and all variables to Other and gone to Data taba and wrote above code and its throwing me error
syntax error on or before :
v6 );
invaled string expression
Can you help me ...plz
Vinnusea
Post by tomok » Mon Sep 27, 2010 7:36 pm
ASCIIOutPut command can only output text, You'll have to convert v6 to text before you can use it in the formula.
vinnusea
Post by vinnusea » Mon Sep 27, 2010 7:49 pm
Yes its working.. Thanks alot.. sir.
Vinnusea
aryan
OLAP Product: oracle
Post by aryan » Thu May 10, 2018 8:59 am
When I am Converting Number to string Only one value is converting and i am getting only one value in the output how to change total data to string
Post by tomok » Thu May 10, 2018 11:46 am
Read the request for assistance guidelines first and then come back with the kind of information you need to be providing. I have no clue what you are talking about.
Version: 10.2.2., PAW
Post by Steve Rowe » Thu May 10, 2018 8:56 pm
Hmmm, you need to convert each field/column/variable to a string independently, so if you have 5 numeric variables then you'll need to write.
AsciiOutput( 'WhyIsThisFunctionNameSoLong.cma' , NumberToString( v1) , NumberToString( v2) , NumberToString( v3) , NumberToString( v4) , NumberToString( v5) );
If that doesn't answer your question then I'm not sure what you are after either..
