Do you have any idea about the percent increase in memmory consumption after upgrading from 9.0 to 9.1?TM1 9.1 Release Notes wrote:In TM1 9.1, the TM1 Server delivers greatly improved concurrency and overall stability, as well as better diagnostics and monitoring capabilities. A side-effect of these necessary changes is that the TM1 Server may consume more memory than in previous versions. The amount of additional memory is primarily model-dependent. Customers who in previous versions have observed that they operate close to the memory limits of their hardware, should anticipate adding additional memory and/or modifying their models using documented TM1 memory optimization techniques. Customers who are currently using 32-bit TM1 Server near the 3 GB limit, may need to upgrade to a 64-bit TM1 Server
As per your experience, how much did it increase?
Our 32bit 9.0 server is using about 2.5GB (near 2GB is for TM1) at the moment. I am trying to find out how much it will require after upgrade and accordingly will need to determine about 64bit option.
