Hi guys,
I'm having a security issue with Cognos Express. When I try to login to the CXMD server I get the error "Unable to Create CAM client object" (Attached Screenshot). This is on IntegratedSecurityMode = 4. However if I switch that back to 2, I get the old TM1 admin login back and I can at least get into the server.
I've tried uninstalling and re-installing Express from scratch, just re-installing Xcelerator but I always get the same issue. The problem arose shortly after I installed the Fix Pack 1 for the client, although it ran fine for about five days before suddenly giving the issue. I have no way of knowing if anyone had made any sort of changes on that day.
Any advice on the matter would be greatly appreciated. Thanks.
-Michael
Express - CAM Client Object Error
- The_Michael
- Version: 9.4
- Capture.JPG (32.08 KiB) Viewed 1820 times
