I've never seen this issue before and was wondering if anyone else has experienced this.
A user logs in, clicks link to websheet from the home page and then clicks the "X" button to close the websheet and return to the home page. All of that works, this issue is when the user does this multiple times the UI starts "Stepping" in. Basically shinking the UI and adding a small column to the right side of the screen. It's as if it's keeping each webscreen open in the background. However, if you "Home" button, it clears it all out and you are back to normal.
Has anyone run into this and if so, why is this occuring and what did you do to resolve this issue?
If no one has encountered this before is there a way to hide the "X" close websheet button in the navigation section.
Thanks in advance!
