After developing with Perspectives for some weeks I've got some questions.
1 - When adding a new Active form to a sheet, you have to give up a name for it, Default is "ARPT1". Does this need to be unique? Why is it used? Except for one or two references in some formula's.
2 - I've noticed differences when starting Perspectives. When I first start Perspectives (the excel plugin) and than open a excel sheet with active form. I've noticed serieus delay when trying to use a Picklist (It seems to calculate a lot, building the piclist) and VBA code is seriously slower (especially while looping).But when I first start with the excel sheet and than activate the plugin, things are working normally. Picklist are instantly usable and the same VBA code is run in a split second. Is this the result of a wrong install or incorrect usage of the software?
3 - When I want to lock the page to protect certain fields. It seems that picklists are no longer usable, they give some vba error and stop working. Is there a fix for this?
4 - This is more a general question. It seems I can log in without having to care if the profilename is uppercase or not. TM1 accepts Admin, admin, ADMIN as the same profile. Is there a way to make this more strict? It could lead to some problems in my VBA. I can work around this but a more strict login procedure would be preferred.
Questions about Perspectives & Active Forms
- rkaif
- Version: 9.1 or later
Re: Questions about Perspectives & Active Forms
ARPT# are used when you have Dependent Sections (Active Forms) in your spreadsheet1 - When adding a new Active form to a sheet, you have to give up a name for it, Default is "ARPT1". Does this need to be unique? Why is it used? Except for one or two references in some formula's.
Try changing the Workbook calculation option in Excel from Automatic to Manual2 - I've noticed differences when starting Perspectives. When I first start Perspectives (the excel plugin) and than open a excel sheet with active form. I've noticed serieus delay when trying to use a Picklist (It seems to calculate a lot, building the piclist) and VBA code is seriously slower (especially while looping).But when I first start with the excel sheet and than activate the plugin, things are working normally. Picklist are instantly usable and the same VBA code is run in a split second. Is this the result of a wrong install or incorrect usage of the software?
Instead of using the Excel protection put your DBRW formula into some Excel formula e.g. =SUM(DBRW(x,y,z...))3 - When I want to lock the page to protect certain fields. It seems that picklists are no longer usable, they give some vba error and stop working. Is there a fix for this?
TM1 Usernames are not case sensitive.4 - This is more a general question. It seems I can log in without having to care if the profilename is uppercase or not. TM1 accepts Admin, admin, ADMIN as the same profile. Is there a way to make this more strict? It could lead to some problems in my VBA. I can work around this but a more strict login procedure would be preferred.
Cheers!
Rizwan Kaif
Rizwan Kaif
- Version: Since 9.5
- Excel Version: All
@rkaif: Thank you for the responses I'll try your tips.
- rkaif
This is a known issue with Excel 2003 and 2007. This is a limitation imposed on TM1 Perspectives by Microsoft Excel. This is not a TM1 limitation or defect. Picklist on Protected sheets will work fine with Excel 2010.rkaif wrote:Instead of using the Excel protection put your DBRW formula into some Excel formula e.g. =SUM(DBRW(x,y,z...))3 - When I want to lock the page to protect certain fields. It seems that picklists are no longer usable, they give some vba error and stop working. Is there a fix for this?
Cheers!
Rizwan Kaif
Rizwan Kaif
