I think it could be a good thing to share/centralize a list of bugs found in the 9.4 version.
From our side, we've already noticed :
- Spreading issue : "Hold" a total/consolidate (Europe), "relative proportional spread" on a subtotal/consolidate child of the previous one (Scandinavia which will have Denmark, Sweden and Norway as children) freeze the TM1 Server (100 % CPU)
- In Slices and ActiveReports, Excel recalculates again and again, specially when you change selection with "subnm", even if the "Recalculate" option is not on "Automatic". It would be nice to be able to recalculate when needed only.
- TI regression : Cube data export does not allow so skip calculations as it should do !
What about you ?
Already a list of "bugs" to provide ?
Robert
TM1 9.4 - List of bugs
- bihints.com
- Version: 9.0.3
- Excel Version: 2003
Re: TM1 9.4 - List of bugs
Maybe Martin could setup a bugzilla on tm1bugs.olapforums.com or similar URL in order to centralise all bugs reports.
That could help everyone to follow bugs/issues for any versions.
- Eric
- Version: 9.4
Setting a hold worked fine with me.- Spreading issue : "Hold" a total/consolidate (Europe), "relative proportional spread" on a subtotal/consolidate child of the previous one (Scandinavia which will have Denmark, Sweden and Norway as children) freeze the TM1 Server (100 % CPU)
Spoke with Dave Corbett. He confirmed the issue and is Actively working to correct it.In Slices and ActiveReports, Excel recalculates again and again, specially when you change selection with "subnm", even if the "Recalculate" option is not on "Automatic". It would be nice to be able to recalculate when needed only.
I will check out after the holiday. Everyone have a great weekend!TI regression : Cube data export does not allow so skip calculations as it should do !
Eric
Eric
- Renaud MARTIAL
Good idea RobertRobertMilli wrote:I think it could be a good thing to share/centralize a list of bugs found in the 9.4 version.
I think it could also be interesting to 'extend' such a buglist to older releases still operating worldwide.
We could then have an idea of what happened to old bugs (and the delay of resolution) ...
Renaud.
