Attribute Cube Rules
Eric
Version: 9.4
Post by Eric » Fri May 16, 2008 8:13 pm
Once again I think I am asking a easy question for you guys, but the syntax is messing with me.
I have the following Rule
['FAMILY'] = S:ELPAR('Codes',!Codes,1);
However, I only want it to calculate for the leaf level. So I tried
['FAMILY'] = S:N:ELPAR('Codes',!Codes,1);
It did not work. Am I doing something wrong? I am guessing I can combind IF & ELPARN but I was hoping for something easier to read (C: & N:).
Kind of like
IF( ELPARN(ELPAR('Codes',!Codes))=0, S:ELPAR('Codes',!Codes,1);
ElseIf (ELPARN(ELPAR('Codes',!Codes))>0,'somthing');
Any thoughts?
Eric
Mike Cowie
OLAP Product: TM1, MSAS
Version: Anything thru 11.x
Excel Version: 2003 - 2016
Re: Attribute Cube Rules
Post by Mike Cowie » Fri May 16, 2008 8:21 pm
Eric,
As you've seen (S:)tring and (N:)umeric don't mix in the same rule. Have you looked at the ISLEAF function?
['FAMILY'] = S: IF(ISLEAF() = 1, ELPAR('Codes',!Codes,1), STET);
At the lowest level this rule will calc the ELPAR and above that you'll be able to in put values (STET = let it stand/no rule calc). I think ISLEAF has been around for a little while now and I use it most often writing drill-through rules.
Eric
Version: 9.4
Post by Eric » Fri May 16, 2008 8:36 pm
Yep I just found that I ended up doing
FEEDSTRINGS;
SKIPCHECK;
['FAMILY'] = S: IF( (ISLEAF = 1)
, !Codes
FEEDERS;
[]=>['FAMILY'];
Thanks!
Eric
