Dynamic subset to select all leaf-level elements, except one
jamesbennett
OLAP Product: IBM Cognos TM1
Post by jamesbennett »
I have a dynamic subset set up based on the following expression:
{TM1FILTERBYLEVEL( {TM1SubsetBasis()}, 0)}
It selects all leaf-level elements within the dimension. Is there a way to modify the expression to remove one particular dimension from the subset?
Re: Dynamic subset to select all leaf-level elements, except one
Except is the function you are looking for
jamesbennett
Thanks you - that works now.
Version: PAL 2.0.9.18
jamesbennett wrote: Fri Jan 18, 2019 11:48 am I have a dynamic subset set up based on the following expression:
Please remove TM1SubsetBasis and use TM1SubsetAll. The former is a relative concept, the latter an absolute one. You will want to have the absolute one, I assume.
IBM Champion 2024
jamesbennett
Wim Gielis wrote: Fri Jan 18, 2019 12:23 pm
Thanks for the head's up!
