Old TM1 version
CellPutN
Version: 10.2.20500.75
Old TM1 version
Post by CellPutN » Thu Jan 10, 2019 4:12 pm
I'm using tm1 since 2016 and I always wonder what older TM1 (Sinper TM/1, Applix TM1) looks like ? Did Sinper and Applix have always used architect ? Did anyone have screenshot of older version ?
Thanks !
jim wood
Version: TM1 10.2.2
Location: 1639 Route 10, Suite 107, Parsippany, NJ, USA
Re: Old TM1 version
Post by jim wood » Thu Jan 10, 2019 4:31 pm
Architect only came with version 7. Before that it was very different. Everything was built in to Excel. Even loading data as there was no TI either.
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 10 64-bit. TM1 Version: 10.2.2
Excel Version: 2010 and 2016
Re: Old TM1 version
Post by Alan Kirk » Thu Jan 10, 2019 6:44 pm
Thanks !
Or built into Lotus 1-2-3. There was a time when Excel support was New! And! Exciting!
From the Perspectives 2.6 manual, this is what the ancestor of Cube Viewer looked like:
And this is what Subset Editor looked like. Unsurprisingly there were no alias buttons at that time, because the concept of an alias had yet to exist:
That functionality is still there in the form of the "Example" and "Process" buttons on the ribbon tab, though I'd lay odds that 95% of TM1 users have never looked at those or know what they mean. There was a VBA based tool (once Excel support came along) which sat over that which you could use to schedule the imports. It was about as reliable as a first generation steam train (as in, Stephenson's Rocket, but less robust) and although I used to use the thing daily I cannot for the life of me remember its name now. My then-boss later-assistant used to loathe it with a passion. (At least it was less finnicky than PAW.)
But who could forget the ability to import / export similarly formatted spreadsheets?
{Pauses... stands up, looks over shoulder in the general direction of 1999, looks at 2019 calendar on the wall....} What the hell just happened?
bgregs
Version: 2.0
Re: Old TM1 version
Post by bgregs » Thu Jan 10, 2019 8:53 pm
@Alan Kirk,
My god that explains the random macros that I stumbled across!! These are still hanging around as of PA 2.0 under the name "IMPEXP_WORKS" and can still be mapped into the Quick Access Ribbon by looking under the "Macros" drop-down. ;)
Re: Old TM1 version
Post by Alan Kirk » Thu Jan 10, 2019 9:41 pm
Ah, now I remember. It was called "Data Control". Clearly a suppressed memory.
@Alan Kirk,
That's not surprising; I don't think that the Perspectives add-in has been cleaned out in a very, very long time. Whether the functionality still works equally in 32 bit and 64 bit is a different matter given the issue with something as basic as the xdi dimension open function. The intention was that PAx would be the cleanout, but, hey... PAW and the curse of Docker. So the legacy code lives on.
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Re: Old TM1 version
Post by Michel Zijlema » Fri Jan 11, 2019 7:22 am
And if we go even further back in time :ugeek: ... there was this interface:
jim wood
Version: TM1 10.2.2
Re: Old TM1 version
Post by jim wood » Fri Jan 11, 2019 12:25 pm
I forgot all about Lotus. I used to love Lotus. With the power keys you could do everything without touching a mouse it was awesome!!
CellPutN
Re: Old TM1 version
Post by CellPutN » Tue Jan 15, 2019 12:54 pm
Wow thanks guys !
Nice to see how TM1 / PAW has improved over years !
