Picklist from Two Dimensions Based on Condition
tm1green
Post by tm1green »
Guys,
Can I have a picklist populated from two other dimensions based on some conditions? For example if condition 1 is true then populate the picklist from dimension A else populate the picklist from dimension B.
Thanks in advance.
Version: PAL 2.0.9.18
Re: Picklist from Two Dimensions Based on Condition
Yes, create a picklist cube with a rule, rather than a picklist attribute.
IBM Champion 2024
