TIEXECUTE
hectorfabios
Excel Version: 2010 y 2007
TIEXECUTE
Post by hectorfabios » Fri Nov 02, 2018 8:09 pm
good afternoon
Currently installed tm1 10.2.2 executing some chores with TIEXECUTE and since last Monday it did not work anymore. The error says that you can not validate and / or incorrect the user and the password. The user and the password have NOT changed. A help that can be. Thank you
Mike Cowie
OLAP Product: TM1, MSAS
Version: Anything thru 11.x
Excel Version: 2003 - 2016
Re: TIEXECUTE
Post by Mike Cowie » Mon Nov 05, 2018 8:39 pm
Hello:
I think you're referring to the TIExecute command-line utility that I shared many, many years ago on this forum. That tool isn't being updated or supported at this point because IBM have since released their own, supported TM1RunTI command-line application that covers the same functionality and more.
As of 10.2.2 FP6 you can use IBM's TM1RunTI to execute chores which should provide exactly what you are looking for:
https://www-01.ibm.com/support/docview. ... wg27048305
It just requires a little conversion from the TIExecute syntax you're currently using.
Hope that helps!
Mike
hectorfabios
Re: TIEXECUTE
Post by hectorfabios » Tue Nov 06, 2018 3:26 pm
Hello Mike. Thank you for your information. I am checking the link that you provided me
Hello:
Hope that helps!
Mike
