TM1 DISPLAYS #N/A VALUES INSTEAD OF "0"
mce
Excel Version: 2013 2016
Post by mce »
In Planning Analytics Local v2.0.5 environment, I created a cube with 27 dimensions and it displays #N/A as value in consolidated cells although there is no rule in the cube at all.
Did you face this issue before? Any comments will be appreciated.
mce
Re: TM1 DISPLAYS #N/A VALUES INSTEAD OF "0"
Post by mce »
Restarting Architect solves the issue.
27 dimensions !
Are you sure?
mvaspal
OLAP Product: tm1
Version: 10 2 2 - 2.0.5
Post by mvaspal »
That can be the case when you are stuck in batch update mode, for example a TI that you run switches it on on the Prolog but then aborts without switching it off on the epilog
