TM1 DISPLAYS #N/A VALUES INSTEAD OF "0"
mce
Version: Planning Analytics Local 2.0.3
Excel Version: 2013 2016
Post by mce » Thu Nov 01, 2018 5:38 pm
In Planning Analytics Local v2.0.5 environment, I created a cube with 27 dimensions and it displays #N/A as value in consolidated cells although there is no rule in the cube at all.
Did you face this issue before? Any comments will be appreciated.
mce
Re: TM1 DISPLAYS #N/A VALUES INSTEAD OF "0"
Post by mce » Thu Nov 01, 2018 5:59 pm
Restarting Architect solves the issue.
Version: 10.2.2., PAW
Post by Steve Rowe » Fri Nov 02, 2018 8:16 am
27 dimensions !
Are you sure?
mvaspal
OLAP Product: tm1
Version: 10 2 2 - 2.0.5
Post by mvaspal » Mon Nov 12, 2018 10:41 am
That can be the case when you are stuck in batch update mode, for example a TI that you run switches it on on the Prolog but then aborts without switching it off on the epilog
