Tm1 integraated Mode 5 RestApi timed out
kavitha2002
OLAP Product: tm1
Version: 10.3.10100.8
Excel Version: 14
Post by kavitha2002 » Fri Oct 26, 2018 12:28 pm
I am using TM1 RestApi in my application with CAM security, the Rest Api in application is session out based on the ClientPingCAMPassport value in the tm1s.cfg file, but cam passport is alive. Currently i have given Tm1s.cfg -> ClientPingCAMPassport=900
REST Api should also be alive until cam passport is alive . Can i give the belo settings?
1)IBM configuration .. Security -> Authentication ->idle time in seconds 3600
2) fpmsvc_config.xml file -<session timeout="60"/>
3)Tm1s.cfg -> ClientPingCAMPassport=3560 few seconds lesser than first one IBM configuration -- security--Authentication ->idle time
and call the logout when 3560 seconds are reached... Which would be better kindly explain me bit clearly.
