Tm1 Web View
Jorge Rachid
Tm1 Web View
Post by Jorge Rachid » Tue Oct 16, 2018 5:30 pm
Hi guys,
I have a cube with many dimension and I have to put some of them on rows.
The problem is that tw1web concatenate the values when the value of a dimension repeats and the visualization of it is not good for the user.
I would like to know if there is a way to solve the problem:
View on TM1 Architect:
The same view on tm1web:
Any helps?
JR.
orlando
Version: PAL 2.0
Re: Tm1 Web View
Post by orlando » Wed Oct 17, 2018 7:03 am
i don't think that you can change this behaviour.
Did you asked the IBM support?
orlando
Re: Tm1 Web View
Post by lotsaram » Wed Oct 17, 2018 9:27 am
Your screenshot seems to show pretty clear evidence of a bug. You should raise a ticket with IBM support.
Jorge Rachid
Re: Tm1 Web View
Post by Jorge Rachid » Wed Oct 17, 2018 12:02 pm
I do not think that is a bug because tm1web concatenate the values that repeat and in my case there is eight dimensions on rows.
Maybe because of that the view is not nice on tm1web.
But I will check the possible to contact the support of IBM.
Thanks a lot,
JR
Version: PAL 2.0.3
Excel Version: 2016 64-bit
Re: Tm1 Web View
Post by gtonkin » Thu Nov 08, 2018 1:02 pm
Coming in a bite late but saw this again today and thought I would post to see if you had tried or were aware of it.
Wrapping string values in cube views
Jorge Rachid
Re: Tm1 Web View
Post by Jorge Rachid » Fri Nov 09, 2018 2:33 pm
Do you think that enabling this parameter the view cube will not concatenate the elements of dimensions anymore?
So the elements would repeat?
Thanks a lot.
JR
Version: PAL 2.0.3
Re: Tm1 Web View
Post by gtonkin » Fri Nov 09, 2018 3:13 pm
I could be misunderstanding the issue as I interpreted "concatenate" in the context of the images as "wrapping".
In theory, the link I posted should help with the wrapping on the text in "Historico"
