returnviewhandle
Moh
OLAP Product: Cognos
Version: 10.1.1
returnviewhandle
Post by Moh » Mon Oct 08, 2018 4:31 am
Good morning sir,what use of RETURNVIEWHANDLE what actually it do.pls give example
daniel.havassy
Re: returnviewhandle
Post by daniel.havassy » Mon Oct 08, 2018 7:28 am
One area where you'd encounter it is drill-through to a TM1 cube view. The drill TI process would have that as a statement in Prolog. If you are new to drill-throughs, check the product documentation of Planning Analytics, you'll find good explanations there.
Post by lotsaram » Mon Oct 08, 2018 9:24 am
One area where you'd encounter it is drill-through to a TM1 cube view. The drill TI process would have that as a statement in Epilog.
Version: PAL 2.0
Post by Wim Gielis » Mon Oct 08, 2018 9:54 am
Emphasis added.
I happen to be working on drill through to cube views the last 2 days. I don’t find the documentation good in this topic.
http://www.wimgielis.com ==> 105 TM1 articles and a lot of custom code
Newest blog article: Looping over input files
daniel.havassy
Post by daniel.havassy » Mon Oct 08, 2018 2:27 pm
Valid point Wim, I guess I shouldn't have used the word "good" or "explanation" :?
