TM1 10.2.2 FP4 on Windows 10 - Subset editor items disappear when using multi-selection
macsir
Version: PAL 2.0.9
Post by macsir »
Element name goes to blank when using shift or control key for multi-selection in subset editor in Perspectives.
But actually the items selected are still valid and there. The names of elements are just showing empty. Any idea?
download (2).png (31.05 KiB) Viewed 4233 times
Version: PAL 2.0.9.18
Re: TM1 10.2.2 FP4 on Windows 10 - Subset editor items disappear when using multi-selection
I have experienced this as well, but I have no clue on what causes and resolves this. So I would like to know the answer too ;-)
IBM Champion 2024
macsir
Version: PAL 2.0.9
Post by macsir »
Wim Gielis wrote: Fri Oct 05, 2018 4:38 am I have experienced this as well, but I have no clue on what causes and resolves this. So I would like to know the answer too ;-)
Thanks, Wim. Most of us are on Windows 7. It is just some users have been upgraded into Windows 10. I am wondering if PA has this issue too. I don't have chance to test it yet.
This bug has been there for a while (happens in dimension editor too). As it is in Perspectives/Architect I'm not holding out any hope of it being addressed.
Happens on PAL too - generally when selecting contiguous ranges holding shift - using Ctrl to pick seems fine for me.
FWIW here's a link to DeveloperWorks where others have noted this issue too:
https://www.ibm.com/developerworks/comm ... dd62189870
macsir
Version: PAL 2.0.9
Post by macsir »
Thanks for the confirmation, guys.
Just got support reply saying it was also an issue with PA Client tools until PA 2.0.2.
Does anyone have any chance to test this bug in the versions after PA 2.0.2?
Seems fine on PA 2.0.5.
For me too, I am on 2.0.5 since a while and I don't recall having the seen the problem in a while. In the past it used to be an issue. Also in the Dimension Editor.
IBM Champion 2024
macsir
Version: PAL 2.0.9
Post by macsir »
thanks for the confirmation.
