TM1 10.2.2 FP4 on Windows 10 - Subset editor items disappear when using multi-selection
macsir
OLAP Product: TM1, SSAS
Version: 9.5 - 10.2
Excel Version: 97 - 2013
Post by macsir » Fri Oct 05, 2018 3:47 am
Element name goes to blank when using shift or control key for multi-selection in subset editor in Perspectives.
But actually the items selected are still valid and there. The names of elements are just showing empty. Any idea?
download (2).png (31.05 KiB) Viewed 287 times
Version: PAL 2.0
Re: TM1 10.2.2 FP4 on Windows 10 - Subset editor items disappear when using multi-selection
Post by Wim Gielis » Fri Oct 05, 2018 4:38 am
I have experienced this as well, but I have no clue on what causes and resolves this. So I would like to know the answer too ;-)
http://www.wimgielis.com ==> 105 TM1 articles and a lot of custom code
Newest blog article: Looping over input files
macsir
Version: 9.5 - 10.2
Post by macsir » Fri Oct 05, 2018 4:57 am
Thanks, Wim. Most of us are on Windows 7. It is just some users have been upgraded into Windows 10. I am wondering if PA has this issue too. I don't have chance to test it yet.
Post by lotsaram » Fri Oct 05, 2018 6:49 am
This bug has been there for a while (happens in dimension editor too). As it is in Perspectives/Architect I'm not holding out any hope of it being addressed.
Version: PAL 2.0.3
Excel Version: 2016 64-bit
Post by gtonkin » Fri Oct 05, 2018 7:08 am
Happens on PAL too - generally when selecting contiguous ranges holding shift - using Ctrl to pick seems fine for me.
FWIW here's a link to DeveloperWorks where others have noted this issue too:
https://www.ibm.com/developerworks/comm ... dd62189870
macsir
Version: 9.5 - 10.2
Post by macsir » Sun Oct 07, 2018 9:40 pm
Thanks for the confirmation, guys.
Just got support reply saying it was also an issue with PA Client tools until PA 2.0.2.
Does anyone have any chance to test this bug in the versions after PA 2.0.2?
Version: PAL 2.0.3
Post by gtonkin » Mon Oct 08, 2018 2:23 pm
Seems fine on PA 2.0.5.
Version: PAL 2.0
Post by Wim Gielis » Mon Oct 08, 2018 3:07 pm
For me too, I am on 2.0.5 since a while and I don't recall having the seen the problem in a while. In the past it used to be an issue. Also in the Dimension Editor.
macsir
Version: 9.5 - 10.2
Post by macsir » Mon Oct 08, 2018 9:24 pm
thanks for the confirmation.
