Missing tm1 section from server.xml - PAL, TM1Web, Integrated login
kaazimraza
OLAP Product: TM1, SSAS, Power BI
Post by kaazimraza »
Hi everyone,
I am working on configuring integrated login for TM1 Web, Planning Analytic v2.04 using https://www.ibm.com/support/knowledgece ... pnego.html from IBM.
I was at the step 4 where yo update server.xml file as described in the section "Modify WebSphere Liberty Profile configuration" on the above URL, and I hit a wall. I am unable to find the "<application id=tm1"..> tag as described in section 4. My server.xml has a tag for tm1web but I believe that's different as in the above URL, there's a separate step for updating tm1web tag.
I did a full blown installation of Planning Analytic on the single machine leaving out Performance Modeller and Cognos Insight. Unsure where did I go wrong.
Any help will be highly appreciated.
Kaz
Bakkone
Re: Missing tm1 section from server.xml - PAL, TM1Web, Integrated login
Post by Bakkone »
I think you can disregard the particular ID of the application. Try putting that in before the other application IDs. You should have PMPSVC, TM1Web etc... before all of those.
kaazimraza
Thanks, I shall give it a shot.
So, basically, absence of tm1 tag wouldn't make a difference?
Kaz
