PAW not working after network changes
- gtonkin
Re: PAW not working after network changes
>docker ps -a returns the same result - just seems like the gateway has not installed.
- gtonkin
Just re-ran scripts\paw.ps1:
PS C:\paw> scripts/paw.ps1
The IBMCognosGatewayURL variable is not set. Defaulting to a blank string.
Pulling social (pa-docker:5000/planninganalytics/social:1.0.50-windowsservercore)...
Get https://pa-docker:5000/v2/: dial tcp: lookup pa-docker: no such host
Execution failed with exit code 1
At C:\paw\scripts\init.ps1:58 char:13
+ throw "Execution failed with exit code $LASTEXITCODE"
+ CategoryInfo : OperationStopped: (Execution failed with exit code 1:String) [], RuntimeException
+ FullyQualifiedErrorId : Execution failed with exit code 1
- Excel Version: Excel 2007
If you ever see the "pulling" message then likely the images are not loaded (or got removed).
- Version: 10.3
I experienced the same issue earlier. We identified that port 80 might be open for other app. Port 80 is generic port number for many applications.
So we updated the PAW/CONFIG/Paw.ps1 file with $environment line to change port number. We changed to port 82 and run powershell as admin. Test the change in powershell by scripts/paw.ps1. PA-Gateway connected----done. Now re-start PAW => ./start.ps1
Everything works.
Hope it helps. Thank You
Dharav
Everything works.
Dharav
- gtonkin
Thanks for the information - unfortunately in my case it did not appear to be something else on port 80 but will definitely add your comments to my ever-growing notes for the next time!
- Version: 10.1.1
- Excel Version: Excel 2010
I am getting a gateway error, it says exited.
I have tried to run the .\WindowsContainerNetworking-LoggingAndCleanupAide.ps1 -Cleanup -ForceDeleteAllSwitches command in powershell but am getting the following error:
.\WindowsContainerNetworking-LoggingAndCleanupAide.ps1 : The term
'.\WindowsContainerNetworking-LoggingAndCleanupAide.ps1' is not recognized as the name of a cmdlet, function, script
file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct
and try again.
At line:1 char:1
+ .\WindowsContainerNetworking-LoggingAndCleanupAide.ps1
+ CategoryInfo : ObjectNotFound: (.\WindowsContai...CleanupAide.ps1:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
Does anyone know what I am doing wrong?
regards, Mark
and try again.
At line:1 char:1
regards, Mark
Is that file in your current directory? It complains it cannot find that PowerShell script.
- Version: 10.1.1
Hi dr.nybble,
I suspected this might have something to do with it. I don't know where the file is, I was just following some advice from IBM website
https://www-01.ibm.com/support/docview. ... bm10881484
They didn't specify you needed the location of the file. How would I find it?
I don't know if you can offer any advice on the issue we have:
we noticed paw webpage said the page isn't working.
We then ran docker ps-a and noticed the gateway was exited.
We then attempted to run scripts/paw.ps1 but this errored saying cannot start service pa-gateway failed to create endpoint pa-gateway on network nat : HNS failed with error : The object already exists
We checked if anything was using port 80 but it didn't appear anything was.
We tried stop and then restart via the admin tool, and rebooting the server and trying scripts/paw.ps1 again (didn't work)
we then decided to try Docker container rm pa-gateway
we then tried to run scripts/paw.ps1 and got an error and when running scripts/paw.ps1 ps the pa-gateway shows as exited 128
any advice would be appreciated!
regards, Mark
regards, Mark
- Version: 10.1.1
Thanks dr.nybble.
Just to be sure, if I copy this script and save it to a folder location I can then run the script in powershell?
Also given the issues I explained in my previous comment do you think running this script would be worth a try or would you suggest anything else?
regards, Mark
regards, Mark
Yes save it and run.
You may first do the following:
docker ps -a | sls gateway
If there are any gateway containers delete them
docker rm <container-id>
Check if the WinNAT module has any static mappings defined (it should not have port 80/443 mapped if there are no gateways):
Get-NetNatStaticMapping
If port 80/443 still show as mappings even after removing any pa-gateway containers try to remove them:
Get-NetNatStaticMapping | Remove-NetNatStaticMapping
Try PAW again to see if the pa-gateway can now bind to port 80/443
Otherwise it's script time......
- Version: 10.1.1
Hi dr.nibble,
many thanks. So we got the container running, not saying exited anymore.
However we noticed in the admin tool configuration that the url's needed to be changed.
Finally we were able to login to workspace but it wouldn't open any books and said, it could not find the TM1 database.
Could this be to do with the network interface order?
You may need to set the 'IPAddressV4' setting in the tm1s.cfg file.
If your machine has multiple NICs then TM1 may choose the wrong one to advertise via the Admin Host.
- Version: 10.1.1
Hi dr.nibble,
Hope you are listening!
We have an issue, separate to the one above, with the pa-gateway container having a status of dead.
The error message says
We are unable to restart the container from the admin tool or via a reboot?
regards, Mark
regards, Mark
Ugh, some kind of Docker problem.
Can you remove it with docker rm ?
- Version: 10.1.1
Hi dr.nibble,
Yes, managed to remove the container, ran paw.ps1 stop, then paw.ps1 and everything is working (fingers crossed).
Apologies for throwing questions at you, but could you answer the following please?
Is it possible to have docker installed on one server and PAW installed on another server? If not what are the main reasons (I assume none of the scripts would work for a start)? So for example say you already have docker installed on a machine, can you install PAW on a different machine but use the docker you already have installed?
regards, Mark
regards, Mark
- mce
- Version: Planning Analytics Local 2.0.x
- Excel Version: 2013 2016
dr.nybble wrote: ↑Fri Aug 23, 2019 6:41 pm Yes save it and run.
Hello, we are having troubles with pa-gateway. not working.
When we try this
we get errors.
any suggestions?
- mce
We also ran the .\WindowsContainerNetworking-LoggingAndCleanupAide.ps1 -Cleanup -ForceDeleteAllSwitches command in powershell but it also errors.
All PAW containers work ok, but PA-Gateway is not working.
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Is there anything interesting in logs? (<PAW>\log\pa-gateway)
TM1 and Data Science blog: 6th article - PAfE + VBA: Commit each cell without pressing “Commit” button.
